PROM ID visible in TunerPro RT?
Old Jul 17, 2018 | 11:53 PM
ULTM8Z's Avatar
Any way to see the PROM ID in TunerPro RT?
Old Jul 18, 2018 | 05:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: PROM ID visible in TunerPro RT?
It is in the ALDL data stream, first 2 bytes.
RBob.
Old Jul 18, 2018 | 08:09 AM
ULTM8Z's Avatar
Thanks. But does that mean that TP is not currently set up to see it yet?
Old Jul 18, 2018 | 11:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Likely as most folks don't need that value. But it can be helpful in keeping track of which BIN is which along with keeping track of data logs relative to a BIN. I use that field for just that purpose.
RBob.
Old Jul 18, 2018 | 11:03 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
In my $8d adx it’s under the item list , default view
Here’s how to add it in your xdf
Old Jul 18, 2018 | 02:03 PM
ULTM8Z's Avatar
RBob.
yep, exact reason i want to see it.
Old Jul 18, 2018 | 02:06 PM
ULTM8Z's Avatar
Thanks Tuned.
Old Jul 18, 2018 | 02:08 PM
Engine: Lb9
Transmission: M20
Lmk if you need a adx or xdf I’ll be glad to share .
Old Jul 18, 2018 | 05:23 PM
ULTM8Z's Avatar
Ok, I see it now. It's not in the SAUJP. I had to use the non-SAUJP to see it.
I'm getting 2C9 in TP, which (according to an online hex converter) works out to 713 which is what I put into the bin.
Thanks guys!!
Old Jul 19, 2018 | 06:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thanks guys!!
Open that parameter to edit it in TP. Then change the value from Hex Digits to Integer. Click OK, then save the XDF.
RBob.
Old Jul 19, 2018 | 09:38 AM
ULTM8Z's Avatar
RBob.
sweet. Will do!
Hg
Apr 22, 2005 02:35 PM
Xenodrgn
Jul 10, 2002 08:46 AM
z28onTweenkies
Feb 6, 2002 12:36 AM
MurphsIroc
May 31, 2001 12:20 PM
GTA88
Feb 13, 2001 10:33 AM
