Memcal Compatibility
Old Feb 18, 2019 | 02:27 AM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
What I want to know is if it is possible to use a '730' memcal in a '165' ECU. Based on pictures that I have seen the memcals seem like they might be swap-able. They seem to be similar sizes. I dont have both on hand to test. But if a '730' memcal would physically plug into a '165' ECU would it damage the computer? Could you reprogram the chip on the '730' ecu with '165' bin and make it run? I could not find this on the forums anywhere. I know this seems like an odd question but it does have a purpose.
Old Feb 18, 2019 | 08:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Memcal Compatibility
Yes, you can use a '7730 MEMCAL in a '7165 ECM. Should either remove the knock filter from the MEMCAL, or remove the external knock filter. Other wise will end up with two knock filters.
RBob.
Old Feb 18, 2019 | 11:11 AM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
The reason that I asked this is one I do not have both memcals on hand. The second is I am running OSE12P which not a lot of people are running here but its worked well for me on my '165' ecu. One thing I did not really look into is the possibility of making a knock sensor functional on my OSE12P on my '165' ECU. In Australia on their '808' ECU they got an internal knock sensor on their memcal before we did in the states. So you can probably see where I am going with this. But basically I would like to use a 90-92 5.7L memcal with the integrated knock filter with a 90-92 5.7L knock sensor and then program the chip to run on OSE12P. I have found some references to this here in the past but I want to find a workable solution for myself and anyone from the US who might decide to try OSE12P. If you can think of any problems with using a reprogrammed later memcal let me know.
Old Feb 18, 2019 | 12:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I don’t know the answer to your knock filter. But if you need a anjf or aujp send me a pm I have a few.
Old Feb 18, 2019 | 12:44 PM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
Those memcals are getting hard to find now days. I need to do some more research but if it comes down to where I need one I will PM you. I appreciate the offer.
formulax4
Oct 7, 2011 10:44 PM
dan_t
May 28, 2011 09:54 AM
DuffMan
Car Audio
Aug 12, 2001 02:44 PM
Tec21-CamaroLover
Apr 22, 2001 11:55 PM
squirrelybird
Car Audio
Feb 28, 2001 06:55 PM
