in and out of closed loop
Old Dec 21, 2020 | 04:34 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
So I noticed while driving my ebl ecm enters and exits out of closed loop quite a lot. I thought once it goes into closed loop it is supposed to stay there?
Old Dec 21, 2020 | 10:35 PM
ULTM8Z's Avatar
Re: in and out of closed loop
What is your O2 sensor setup?
My first suspicion would either be a faulty O2 sensor, or sensor wiring. Or if you have a single wire O2 sensor with exhaust headers, in which case what commonly happens is the sensor cools off and stops outputting a signal to the ECM, at which point the ECM goes into open loop.
Old Dec 21, 2020 | 10:56 PM
msammy93's Avatar
Engine: 383 TPI
It's a new ac delco 3 wire heated o2 sensor. The sensor is actually very close to the top of the engine.
It uses to work fine, the issue with the open and closed loop only started today.
Old Dec 22, 2020 | 12:16 AM
ULTM8Z's Avatar
I guess I'd check the wiring on the sensor. What brand sensor?
Other thing the ECM needs for closed loop is reaching the correct coolant temp. So check the coolant temp sensor as well.
Old Dec 22, 2020 | 12:23 AM
msammy93's Avatar
Engine: 383 TPI
It's an AC delco O2 sensor.
Old Dec 22, 2020 | 11:24 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
It's supposed to while driving, it's your Power Enrichment...
- Rob
Old Dec 22, 2020 | 01:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
- Rob
Along with this open loop decel is likely set. This prevents surging on coast down.
RBob.
Old Dec 22, 2020 | 03:36 PM
msammy93's Avatar
Engine: 383 TPI
RBob.
Okay that explains it then. I was going ask about that just now but you answered it ahead of time. If you don't mind answering, if knock recovery is set to high, would that lead to high knock counts? Also, if my knock retards is set to 4°, would that 4 degree stack if it still hears pinging, or would it just go to a max of 4 degrees and it keeps pinging it will not retard anymore?
Old Dec 22, 2020 | 06:48 PM
GeneralDisorder's Avatar
Knock recovery refers to how quickly it adds the timing back in after it stops seeing any knock feedback.
When are you seeing knock counts? It is normal to see a bunch on startup due to the noise from the starter.
If it's set to 4 degrees that's the most it will pull. If pulling 5-10 degrees out doesn't solve it, then it's likely not real detonation.
GD
88 350 tpi formula
Sep 3, 2013 08:01 PM
slickfx3
Sep 19, 2009 04:28 AM
91350rs
Dec 18, 2008 02:24 PM
91blackgta
Oct 30, 2003 02:32 PM
