Blueprint 400 w/First Fuel Injection
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
Hello guys, I was hoping to a little more help. I think I'm almost finished with my tunes. Just a couple things I'm having trouble with.
1, There feels like a miss while I'm cruising and the tps is under 5. I'm thinking it's the tune as just a little gas and the miss goes away.
2. When I take let completely off on the gas, there is a couple lurches as if the pedal is tapped a couple times.
I attached my latest bin and a csv. The miss occurred at 6.25 and 7.17 engine run time. There are plenty of other times that the miss happens, these instances are just when I looked down and saw the exact time.
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Blueprint 400 w/First Fuel Injection
For number #2, have you checked SA on Decel? Also DECEL and DFCO. Your log is incomplete! There is no Injector BPW and FPW. Also your Ref-SA is weird not going over 13* despite your tables showing over 20* Do you have the .XDL file?
Car: 92 Trans Am
Engine: 350 tpi
Thanks for replying.
Attached is the xdf. The extension has been changed to ecu so I could upload. I got rid of some values in my adx file to make it simpler to work with. Doesn't Ref-Sa value equal timing added to base. My base is at 15. Injector BPW is column "N". What tables should I change for decel? I have a 7730 ecm.
Engine: LT1 6.2L
Axle/Gears: 3.91
I'm not familiar with DECEL, I was just suggesting that could be something to look into.
I'm pretty sure I've read stuff on forums about engine surge on decel with EFI. Maybe you want to do some research in the forum (time consuming I know!)
DO YOU have your .xdl?
Car: 92 Trans Am
Engine: 350 tpi
I ended up adding usec in the Injector pw correction if pw is under 3.90ms. It seems like both problems are fixed.
Engine: LT1 6.2L
Axle/Gears: 3.91
What kind of injectors do you have? Do you have the 7730 ecm speed density system?
Car: 92 Trans Am
Engine: 350 tpi
I have bosch III 36lb and it is 7730sd. I noticed that the miss was coming when injectore pw was under 1.40. Here is a cut & paste of my table:
320.435
213.623
152.588
137.329
91.553
61.035
45.776
15.259
0.000
0.000
0.000
0.000
0.000
0.000
0.000
320.435
213.623
152.588
137.329
91.553
61.035
45.776
15.259
0.000
0.000
0.000
0.000
0.000
0.000
0.000
Engine: LT1 6.2L
Axle/Gears: 3.91
Engine: LT1 6.2L
Axle/Gears: 3.91
BPW ... µsec
0.486 ... 328.4
0.729 ... 243.4
0.973 ... 175.8
1.216 ... 126.9
1.459 ... 102.4
1.702 ... 83.8
1.945 ... 74.4
2.188 ... 62.7
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
FWIW ---
In full disclosure, I'm one of those who recommends zeroing the low PW table if exact (note "exact") values are not known from the injector manufacturer. Why? Because that addition without knowing what's happening under the covers is like throwing a dart while blindfolded. Ditto to a degree for voltage offsets. Both of these compensations do nothing more than add a respective PW to the calculated SD BPW.
Now to the real issue here: Single Fire (SF) Mode. By default, Factory $8d AUJP and S_AUJP have the following settings for SF:
Looking at the log and bin provided in Post #1, these values have been changed to:
IMO, what really should be done is to increase the SF mode Scalars to avoid SF Mode below a given PW. Not sure what that threshold is, but would seem to be a better approach than just throwing PW at a low value to compensate. Remember, Factory SF mode values are for a stock engine idling at say 500-600 RPM.
Regarding Decel (DFCO) in the discussion, there are MAP and TPS% Scalars that control when it's invoked and exited. During DFCO, SA-REF and PW will =0.
Elky
PW below which SF is invoked. SF =2x calculated BPW every 720 deg of crank rotation). Normal (Double Fire) =1x calc BPW every 360 deg.
0x3ED: 0x00,0x38 =0056, 0.855ms, FUEL OUT PARAM, Enable Single Fire Mode if PW <
PW required to return to Double Fire from SF
0x3EB: 0x00,0x48 =0072, 1.1ms, FUEL OUT PARAM, Remain in Single Fire Mode if PW <=
This means that any time BPW is between 0.855 and 1.1 ms, SF Mode will be invoked. On a modified engine with large injectors, this generally will mean there is too little fuel in this PW range for proper operation. Adjusting these values to invoke Single Fire at a higher PW solves the "stumble" issue because sufficient fuel is provided.Looking at the log and bin provided in Post #1, these values have been changed to:
0x3ED Invoke SF 0.763ms
0x3EB Disable SF 0.8ms
Not sure the reason, but certainly limits SF Mode. But even with these settings, here are stats of being in SF Mode:0x3EB Disable SF 0.8ms
Min RPM 1375
Max RPM 3800
Median RPM 2175
Count 94 3.2%
Even with the above reduced SF mode PW values, the engine is in SF mode 3.2% of 2890+ samples at a median RPM of 2175.Max RPM 3800
Median RPM 2175
Count 94 3.2%
Elky
Engine: LT1 6.2L
Axle/Gears: 3.91
FWIW ---
Elky
Min RPM 1375
Max RPM 3800
Median RPM 2175
Count 94 3.2%
Median RPM 2175
Count 94 3.2%
Elky
Engine: LT1 6.2L
Axle/Gears: 3.91
But it's something I will keep in mind.
If I understand correctly, the threshold is based on BPW and not corrected BPW. So adding PW won't prevent the single fire mode. However in single fire mode, we will get more PW with the adder.
Car: 84 El Camino
Engine: 360 TPI
Calculated SD PW
CL o2 correction of Calculated SD PW (based on BLM deviation from 128, Rough and Fine corrections based on INT diff from 128, and adjustment if in Decel Enlean)
Compensated PW after CL o2 correction (low PW and voltage compensations), which provides Final PW sent to the ECM to fire injectors
Here's order of activity to create Final PW beginning with CL o2 corrected PW (if OL, then begin with SD PW):If in AE-MAP, add AE-MAP PW
Reduce AE-MAP PW if also in AE-TPS
Set firing mode SF or DF based on SF PW thresholds
Add low PW compensation irrespective of firing mode (but not when asynchronously adding fuel for AE-TPS, DFCO Stall Saver or A/C first on)
Add voltage offset PW compensation irrespective of firing mode
Send compensated PW to ECM
So yes, adding PW if PW is low won't prevent SF and yes, will get more PW with the low PW adder. But a few things to consider:Reduce AE-MAP PW if also in AE-TPS
AE-MAP can be activated during idle, and is frequently = more fuel
I try to avoid SF unless truly idling (low RPM). And with my cam, don't want any unnecessary fuel added while doing everything else possible to have a lean idle.
Can have low PW adder even in DF
Maybe it's just me, but I don't want an arbitrary addition of fuel unless I'm using the low PW table to tune idle with a WB, which I guess is an option -- just one I choose to avoid.I try to avoid SF unless truly idling (low RPM). And with my cam, don't want any unnecessary fuel added while doing everything else possible to have a lean idle.
Use of Low PW is like whether one chooses to use the PE spark adder table. I personally choose to zero that table and tune using only the main spark tables. Guess in all of this, that's why there's chocolate and vanilla ice cream
. Thread Starter
Car: 92 Trans Am
Engine: 350 tpi
FWIW ---
Elky
Min RPM 1375
Max RPM 3800
Median RPM 2175
Count 94 3.2%
Median RPM 2175
Count 94 3.2%
Elky
Engine: LT1 6.2L
Axle/Gears: 3.91
Not sure I exactly understand the question due to PW semantics, but see if this helps. There are really 3 pulse widths:
Calculated SD PW
.Thread
