Anyone have a schematic for a cable for the ALDL to a laptop???
Old Feb 25, 2002 | 10:33 PM
CamaroX84's Avatar
I just got a laptop and I want to start logging data. I don't want to spend 60 bucks for a cable, however. My friend is an electrical engineer, so he can make a cable if he has the schematic. Any help would be greatly appreciated. Thanks.
Old Feb 27, 2002 | 12:27 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
http://www.winaldl.webhop.net/
Old Feb 27, 2002 | 01:16 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
You'll need to use Moates' sofware. The one posted above works for 160 baud i.e. TBI and older ECM. Search for Moates' software and follow the link. At the bottom of the page he has a diagram for his software.
-lars
Old Feb 27, 2002 | 02:54 PM
CamaroX84's Avatar
Can't find the schematic on Craig's site. Thanks.
Old Feb 27, 2002 | 03:06 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
better link
Here's a better link:
Get the software here:
http://ice.prohosting.com/moates/gmecm/index.html
The scematics LINKS are at the bottom of the page right under the place where it says "Further information on Software:"
Click on MAX232, or MAX 233 or Two transistor.
Lars
Old Mar 2, 2002 | 06:52 PM
CamaroX84's Avatar
Which one of those is for our TPI cars? It looks like a couple of those are OBD II. Thanks.
Old Mar 2, 2002 | 09:02 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I am using 2 Resistor one. It works great with my car.
Old Mar 5, 2002 | 06:41 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Hey any body having trouble getting this to work on WinXP? It won't start on mine even after i run the add on thingy. ( thats the techinical name)
Old Mar 5, 2002 | 07:00 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Do you mean WinALDL ?
If you do then it is because the directorys are differnt and the instocx.bat does not support XP yet. You have to install the ocx file manually to make it work.
Copy the file msflxgrd.ocx to the c:\windows\system32 directory.
Then click [Start] and [Run]. In the entry field you type:
regsvr32.exe msflxgrd.ocx
and click [OK]
The dialog should say that it succeded.
Old Mar 5, 2002 | 07:50 PM
BMmonteSS's Avatar
Car: 84' Monte
Thanks a ton that worked perfectly!!
Old Mar 5, 2002 | 10:15 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Since two-way communication is required for 8192-baud, you will need to use at least the two-transistor design. I don't think the 1-transistor design that works with WinALDL for 160 will work on 8192.
If anyone knows different, please pass along. To my knowledge, at least the two-transistor (no personal experience, only MAX232/233) is needed for 8192 with my program, at least I think so.
-Craig
Old Mar 6, 2002 | 11:07 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I recommend the MAX232 circuit. The 500ns switching times of the trasistors stresses CMOS inputs.
cheers,
J
$750 L98
Feb 1, 2025 02:25 PM
thunder57
Nov 7, 2015 02:28 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
