Anyone know what the cylinder volume is for a 406?
Old Mar 4, 2002 | 01:52 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
My math sucks, I did a search and didnt find the answer.
Old Mar 4, 2002 | 02:09 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
By cylinder volume, do you mean the volume in a single cylinder? If that's what you mean it's 50.75 cubic inches (406/8).
Old Mar 4, 2002 | 02:31 PM
drive it's Avatar
Re: Anyone know what the cylinder volume is for a 406?
To get a little more detailed-if it's overbored to 4.155 and stroke of 3.75=833.2cc. times 8=406.8ci.
Old Mar 4, 2002 | 02:36 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
I think i figured it out...a 5.7 has 713 352cu so a 406 should be somewhere around 821/822, 821 works out to 400 cu, 822 is 408 its in ml. IM trying to set the cylinder volume for a 406 in tunercat.
Old Mar 4, 2002 | 02:59 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Thanks drive it......
Old Mar 4, 2002 | 10:05 PM
MR.HP's Avatar
305=624.7,350=717.,355=727.,383=784.5,406=831.6,421=862.4
Thats all that I have in my notes for now
Dale
Old Mar 4, 2002 | 11:06 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
For a 4.155" bore x 3.75" stroke, I get 833.23 cc per cylinder, which is close to what Dale gets.
FYI, since the Volume is trying to convert 1,000 cc (the max value) by 255 (max hex value), the "Cylinder Constant" will only vary in 4 cc increments. So you MIGHT enter 833, but the eprom may only permit a value + or - 4 cc from 833 and the next increment must be 4 cc greater.
Just like the spark advance will must change in .3 or .4* increments, not .1* due to the conversion to "hex".
Old Mar 4, 2002 | 11:15 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
I see......I was wondering why the values changed slightly when I returned to the table. I used 833 for the cylinder volume. IM ready to burn...If I only had some chips.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
