swapping to 6 speed, which bin to start with?
Old Mar 24, 2002 | 05:14 PM
u r sofa king we tah did's Avatar
its a 89 MAF 350 TPI, putting in a T56, will a 350 auto bin work or do i need to use a 305 manual bin?
Old Mar 25, 2002 | 12:25 AM
wuter's Avatar
Why not start with a manual vette bin?
Old Mar 25, 2002 | 12:56 AM
is there a way to disable the oil temp sensor in the bin?
Old Mar 25, 2002 | 02:20 PM
leirch's Avatar
I would start with a 305manual fbody bin, do not start with an auto, the car will never seem right again. I've been there and done that.
Brendan
Old Mar 25, 2002 | 06:29 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
What about the AYPY bin? I thought I heard somewhere that it is the manual transmission equivalent of the ARAP bin. Someone please correct me if I'm wrong because my friend was planning on running that bin on his '88 Vette after he swaps in a 6 speed.
Old Mar 25, 2002 | 07:12 PM
Oops I meant APYP not AYPY. That one was from a full size truck. APYP is from an '89 six speed Corvette. That's the one you want.
Old Mar 29, 2002 | 10:26 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Arent the Vette ones Speed Density?
I started with the ARAP on my T56 setup. I had idle problems before and I still am
Old Mar 29, 2002 | 11:44 AM
HighHopes85's Avatar
The 89 Vette used MAF and the manual tranny BINs were for the ZF6. Remember though that the Vettes got stacked with Al heads so you will need work right away with the spark curves. -Matt-
Old Mar 29, 2002 | 02:37 PM
ImportsRsloths's Avatar
Where do you find a 89 zf6 vette bin to start with???
Old Mar 29, 2002 | 03:50 PM
You can find it on the DIY_EFI ftp site. The bcc for the '89 Vette 6 speed bin is APYP
Old Oct 5, 2002 | 09:47 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I just checked the APYP bin, TunerCat says it's for an automatic transmission not a manual like all ya'll are saying.
Old Oct 6, 2002 | 10:54 PM
ZZsmpch's Avatar
You sure about that? Maybe you got a hacked copy or something.
Old Oct 7, 2002 | 09:25 AM
Engine: 4.0L
Positive. I got the bin right from DIY database. The "manual transmission" box is NOT checked.
Old Oct 7, 2002 | 08:05 PM
ZZsmpch's Avatar
Hmmm, I got mine there too, and it was. What does your copy have in for TCC?
Old Oct 7, 2002 | 08:24 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got 2 copies of APYP. I think that at least one of them came from DIY EFI. Both copies have the manual transmission switch checked.
Old Oct 7, 2002 | 08:27 PM
Engine: 4.0L
The copy of APYP I just downloaded again from diy-efi doesn't have the manual trans box checked and the TCC lock/unlock settings are 0 mph.
Old Oct 8, 2002 | 08:07 AM
Jim85IROC's Avatar
That's odd that the TCC lock/unlock settings are 0mph if it's not a manual-transmission BIN. I'm guessing that somebody's messed with that copy.
Old Oct 8, 2002 | 10:52 AM
kevinc's Avatar
Car: 1982 Z28
Check the TDF version (assuming you're running TunerCat) as the older TDFs definitely had the wrong address location for transmission bit.
The current TDF version numbers are listed on his site, if yours is older (and a legal copy) as for an update.
Old Oct 8, 2002 | 04:10 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, seems odd. APYP is supposed to be a manual transmission bin for an '89 Vette. Yet the option flags are set for an auto trans.
Did that year Vette w/a 6-spd have skip shift? It is possible that the TCC code is being used to handle the skip shift solenoid.
Just another thought,
RBob.
Old Oct 9, 2002 | 05:26 AM
Engine: 4.0L
My TDF is way out of date. I will get the latest version and try.
Old Oct 9, 2002 | 10:07 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
all the manual trans MAF bins I have seen have not have the manual trans box checked. I used the APYP with MAF and T56. It is similar to the ARAP for autos.
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
86Base
Aug 8, 2015 01:34 PM
92projectcamaro
Aug 6, 2015 01:20 PM
