Minimum LV8 to Enable Power Enrichment
Old Apr 6, 2002 | 08:39 AM
Frank88's Avatar
I'm starting to look at data for my 165 ECM. One of my settings is minimum lv8 to enable PE, which is set to 20.
The weird thing is that almost all of my <50% throttle data shows LV8 much higher than 20, leading me to believe that there's always some PE going on. Any thoughts, comments, or experience? What are you other MAF guys running for this?
thanks
Old Apr 6, 2002 | 09:15 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Minimum LV8? Funny, I though it was Minimum TPS to enable PE on all the hacks/TDFs I've seen.
Old Apr 6, 2002 | 10:35 AM
Frank88's Avatar
Looking through the BUA hack, I think it's supposed to be minimum DELTA LV8. Still trying to find exactly how it's used i.e. delta in (presumably) what time-frame???
Old Apr 7, 2002 | 09:48 AM
Car: Death Mobile
Engine: 666 c.i.
The table you are referring to is just another factor in enabling PE...and since LV8 is actually a derivative from the TPS...it really is based on TPS too.
But, if you look a little harder, there is DEFINITELY a Power Enrichment Table based on %TPS and RPM - just like all the other GM Bins I have checked. It took me just over 3 minutes to find it in the BUA hack.
But, if you STILL can't find it, I will give you a hint - look around LC60E.
Old Apr 7, 2002 | 12:36 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I'd venture a guess it's % change in one loop of the code. There are several loops that run, so again that would effect what the time frame is. This is again where fully commented code matters ALOT.
Azrael91966669
25
Jun 20, 2017 04:04 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
