car alarm installation
Old Sep 13, 2000 | 04:56 PM
8Formula7's Avatar
Posted this on the previous website, but ran into a technical problem that i hope any one help.
bought an Audiovox AA-9347 car alarm. Features include light flasher, starter kill, 2 stage shock sensor,etc.
My question concerns the correct wires to cut and splice. Here's what the instructions say to do:
"..get access from to the wires coming from the ignition switch. Connect the RED wire from the relay (alarm) to the wire from the ignition switch that shows +12 volts on the logic probe when the key is switched to the "ON or RUN" and "START" positions, and shows 0 volts when the key is switched to the "OFF" position. I think that this wire is YELLOW (based on info from the wiringinstructions.com website.) There is a series of wires underneath the steering column; is the yellow wire in this group the one that I should use?
The next step in the instructions says:
"...Locate the wire coming from the ignition switch that shows +12 volts on the logic probe when the starter motor is cranking, and shows 0 volts when the key is switched "OFF","ACCESSORY", and "ON or RUN" positions. Cut this wire and attempt to crank to verify. What wire is this? What color is it? To this cut wire I have to splice in two separate wires from the alarm harness.
Now, onto the light flasher. I understand to connect one wire to the wire coming from one of the flashers. The next step says:
"...Connect both the RED wire from relay and WHITE w/ BLACK stripe wire from the relay to a +12 volt battery fused wire (minimum 15 Amps)...these wires can be connected to the + terminal at the battery, and must use in-line fuse (15 Amps)." Is the this the advised way to connect this? Or should I connect to the fuse block with an inline fuse?
Please be as specific as possible; I'm not that familiar with wiring and I don't want to screw up the electrical system. By the way I have an 87 Firebird, with power windows and no power locks. No accessory position in the ignition switch.
Thanks,
Kyle Donohue
Ponty87bird@aol.com
Old Sep 13, 2000 | 07:49 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Here is color code for our 3rd gens from the ign. switch: +12 volt is red, +12 v ignition is pink, starter is purple or white(depending upon year).To check for this,take a test light and probe the white wire and crank the engine.If the light comes on,that's the starter wire. If not then try the purple wire. Accessory is brown, parking light wire is brown from the light switch, door trigger is the white wire from one of the courtesy lights under the dash. As far as the power source goes, you can go directly to the battery or you can splice into the red wire from the ign harness.Either way, you must use the in-line fuse. Hope this helps.
"So,tell me Mr. Stang. How's life like living in the exhaust of a Chevy V-8?"
Old Sep 13, 2000 | 11:31 PM
Jeffro89formula350's Avatar
http://www.wiringinstructions.com/
wiggle your way though the guest mode and you can print out a complete wiring diagram for wiring an alarm in your car.
89 Formula 350
Rebuilt suspension, Aluminum Driveshaft, 3.70 gears
T56 siting in my garage till next months swap.
Best 1/4 mile - 15.08 bone stock.
Old Dec 12, 2025 | 05:00 PM
AgencyspakE's Avatar
Re: car alarm installation
Π”Ρ€ΡƒΠ·ΡŒΡ, всСм ΠΏΡ€ΠΈΠ²Π΅Ρ‚! Нас Π² ΠΊΠΎΠΌΠΏΠ°Π½ΠΈΠΈ попросили срочно ΡΠ΄Π΅Π»Π°Ρ‚ΡŒ Π½Π΅ слоТный сайт с ΠΎΠ±ΡΠ·Π°Ρ‚Π΅Π»ΡŒΠ½ΠΎΠΉ ΠΈΠ½Ρ‚Π΅Π³Ρ€Π°Ρ†ΠΈΠ΅ΠΉ N8n. Π― Π² этом совсСм Π½Π΅ Ρ€Π°Π·Π±ΠΈΡ€Π°ΡŽΡΡŒ, поэтому ΠΏΠ°Π½ΠΈΠΊΡƒΡŽ. ΠΠ°Ρ‡Π°Π»ΡŒΠ½ΠΈΠΊ попросил Π½Π°ΠΉΡ‚ΠΈ! ΠŸΠΎΠ΄ΡΠΊΠ°ΠΆΠΈΡ‚Π΅, поТалуйста, ΠΌΠΎΠΆΠ΅Ρ‚ Ρƒ ΠΊΠΎΠ³ΠΎ-Ρ‚ΠΎ Π΅ΡΡ‚ΡŒ Π·Π½Π°ΠΊΠΎΠΌΡ‹Π΅ ΠΏΡ€ΠΎΠ²Π΅Ρ€Π΅Π½Π½Ρ‹Π΅ Ρ€Π°Π·Ρ€Π°Π±ΠΎΡ‚Ρ‡ΠΈΠΊΠΈ ΠΈΠ»ΠΈ студии, ΠΊΠΎΠΌΡƒ ΠΌΠΎΠΆΠ½ΠΎ Π΄ΠΎΠ²Π΅Ρ€ΡΡ‚ΡŒ? Π‘ΡƒΠ΄Ρƒ ΠΎΡ‡Π΅Π½ΡŒ Π±Π»Π°Π³ΠΎΠ΄Π°Ρ€Π΅Π½ Π·Π° ΠΊΠΎΠ½Ρ‚Π°ΠΊΡ‚Ρ‹!
- use website technologies ссылка
Old Dec 13, 2025 | 12:36 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
On hearing a car theft alarm go off..."A car is being stolen, quick call the police"! Says NO ONE , ever.
Jbalgiere
Mar 25, 2021 09:24 PM
johnw999
Feb 13, 2017 10:45 PM
xxZ28xx
Aug 7, 2012 09:10 PM
jb3829
Jul 4, 2012 05:28 PM
sam24th
Dec 5, 2009 03:41 PM
