Air Bag
Old Jun 3, 2002 | 11:47 AM
92 3.1 Rs's Avatar
Air Bag
Guy,s I have a 1992 rs with the 3.1 in it. My air bag light came on and I was wondering what causes this. It stays on and doesn't go off till the car is shut off.
Old Jun 3, 2002 | 12:43 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
Let me guess the infl rest light sits there and flashes at you like you should know what to do. i have this same problem and unfortuanately noone knows what to do. this means that your airbag system is disarmed either due to low voltage (could be cause by a bad alternator) or your air bag is no good. there could be a short in the system somewhere or possibly one of the sensors could have gone bad. there is only one way to find out. take it to the dealer. (not your drug dealer) although he might make you feel better bout this but it will only make you forget until the little red light comes on again. damn i hate that thing. if i was you i would rip out that bulb, take your air bag and all the sensors and have a bon fire!!!!! ahhahahhaha
Old Jun 3, 2002 | 12:55 PM
92 3.1 Rs's Avatar
Well my light doesn't flash it stays on. Im probably going to end up taking it to a dealer
Old Jun 3, 2002 | 02:25 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
IF YOU FIND OUT WHATS WRONG PLEASE TELL ME I NEED TO KNOW TOO.
Old Jun 3, 2002 | 04:54 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
airbag diagnostics
Check the SIR fuse first.
If okay, check the DERM module connector is still connected. This is under the passenger side of the dash. Silver box, yellow connector.
If these are okay, let me know and we will try to check further in.
By the way, when ignition is first turned on, does the lamp blink 7 to 9 times, or does it come on and stay on?
Andy.
Old Jun 4, 2002 | 11:47 AM
92 3.1 Rs's Avatar
The light does flash when the ignition is turned on. I checked the silver box and found nothing to be wrong. The light fist blinks then it stays on.
Old Jun 4, 2002 | 04:26 PM
Car: 91 camaro rs
Hi 92 3.1 Rs
Did you check the SIR fuse in the fuse box?
Right, this is important! We have to follow a procedure through.
Answer me these as well as you can.
1) Switch ignition on and count the number of flashes. Let me know.
2) As the engine is cranking, does it stay on or go off?
3) When engine is idling, does the light stay on or does it flash?
After the answers to these I will be able to take you through a routine specific to your fault.
Speak to you soon.
Andy.
Old Jun 5, 2002 | 11:40 AM
92 3.1 Rs's Avatar
The fuse is good and the light flashes seven times. When the car is cranking the light still flashes. At an idle the light stays on.
Old Jun 5, 2002 | 09:53 PM
1991rscamarodem's Avatar
mine does the same.....what is it? i was told the derm.
Old Jun 6, 2002 | 03:04 AM
Car: 91 camaro rs
Not necessarily the DERM.
I am away from my files until saturday now (short holiday in London)! So. if you can hang on till then I will post the whole procedure.
Sorry for the delay!
My Wife banned all thirdgen literature from our hols!
Can't understand why!!?
Andy.
PS Pouring down in London. (No surprise there then!).
Old Jun 6, 2002 | 11:06 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
No worries bro but I would like that proceedure too I hate that stupid infl rest light it has been pleaging my car for too long im about to rip the bulb out but i would like to get it working.
Old Jun 6, 2002 | 11:52 AM
92 3.1 Rs's Avatar
I took my car to a friend that works on cars. I just had an alarm installed and they tapped into the wire for the air bag sensor.
My friend was checking the continuity betweem the sensors and found there to be none in the front sensor.I am going to put a new front sensor in to see if that helps out.I will let you know if it works out.
Old Jun 8, 2002 | 02:01 PM
Car: 91 camaro rs
Okay.
Back home again!
Right.
1) check the CRANK fuse (3A).
2) Pull DERM module out of dash, (but leaving it connected to harness)-from the top, dashpad removed. Using a digital voltmeter (a modern one, otherwise the airbag can deploy) and sitting in the passenger seat (i.e away from the airbag, in case of deployment), back probe the pin marked B10 in yellow connector to DERM while engine is cranking. If this is less than cranking voltage, go to 3, if it is cranking voltage, go to 4.
3) Switch ignition off, disconnect DERM and measure the resistance of terminal B10 on the DERM connector compared to ground. If it is 10 ohms or less, replace DERM. If it is over 10 ohms, repair break or bad connection in purple/white wire that goes from the CRANK fuse to terminal B10.
4) Check for good terminal contact at pin B10 at DERM. If pin contact is good, replace DERM.
Hope this helps.
Andy.
Old Jun 14, 2002 | 02:02 PM
92 3.1 Rs's Avatar
I put a new front crash sensor in and i've had no problems at all.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
edoff13
Sep 11, 2015 03:55 AM
Ian Irvine
Sep 4, 2015 08:08 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
