MULTI-FUNCTION LEVER
Old Dec 14, 2000 | 11:19 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
The question I have is why would there be more resistance when I turn on the left signal vs. the right signal? When I turn on the right, it "snaps right in to place". When I turn on the left, I can feel alot more resistance. It will "snap in" and stay locked as well, and disengage as advertised after coming out of a turn. It really isn't a big deal, just thought that it should have pretty equal force required to engage it. Is there a way to correct this, other than having to replace it. Maybe a sign of impending failure?
KAM
Old Dec 14, 2000 | 11:55 AM
Stuart Moss's Avatar
Sounds like there is something interfering with it. Look into the slot where enters the column and see if you can see anything that may cause it to get caught on something.
Otherwise, I'd suggest you remove the steering wheel (you'll also need the lock plate removel tool - ~$18) and obsere the mechanism while it is working to see if you can determine why there is added resistance.
wigmobile
Feb 26, 2025 02:56 PM
ndndndnd
Sep 28, 2015 08:00 AM
tattmann
Sep 27, 2015 05:20 PM
Todd84Z
Sep 4, 2015 08:02 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
