Voltage needle jumps when turn signals are on
Old Dec 11, 2000 | 06:37 PM
need 4 speed's Avatar
The problem is every time I turn on my turn signals,my voltage jumps back and forth.
I think the tach does to,but can't remember.
Shortly after I noticed this my alternator
died.So to be safe I replaced the battery
to.Still did'nt fix the problem.It's a 89
TA tpi 350 with 55,000 miles if that helps.
Any ideas?????? thanks.
89 Trans Am tpi 350
Flowmaster
Catback
Shift Kit
Stall converter
Corvette servo
Tpis airfoil
K&N'S
MSD super conductor wires
Free mods
Old Dec 13, 2000 | 07:13 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
It's notmal for the voltage meter needle to deflect, slightly, when the turn signal bulbs turn on in a flash cycle, however, if the tach needle is deflecting in sync with the turn signal flash rate, the system voltage is too low.
Tim
Old Dec 13, 2000 | 08:54 AM
Tim,
The tach needle does move in sinc with the turn signals.Any ideas on the low voltage? I know that it could be alot of things,any ideas on where to start?
Thanks,
Dan
Old Dec 13, 2000 | 06:08 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I have the same problema nd i have a 140 AMP alternator on y car too
Old Dec 14, 2000 | 02:11 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
It's normal for the voltage needle to twitch along with the blinkers. But the only time I've seen the rest of my gages fluctuate with the blinkers was when my alternator died. I suppose it's possible that you got a bad alternator. Did you buy a reman? Those things are notorious for not working. If I were you, I'd check to make sure the alternator was charging. If it is, then just drive around and see if you're having any other problems. But I suppose it's hard to get anywhere in this snow. (I'm only a few miles away in Lawrence)
Old Dec 14, 2000 | 07:05 PM
If the problem occurs only at idle, then it's probably the alternator, or a weak battery, or both.
Also, when you wash your engine, make sure that you cover the alternator so that it does not get wet. I killed a few alternators, that way....
Tim
Old Dec 14, 2000 | 07:09 PM
Tim
Old Dec 16, 2000 | 10:07 AM
Thanks everyone for youre help. When the snow melts I'll have the alternator checked.
Old Dec 25, 2000 | 01:38 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The reason your tach may be dropping is that some ecms will adjust the pulse rate for certain engines when the voltage drops below a certain value. This is to compensate for the injectors not having the same current as when it is fully charged (14.4 volts). So your engine may infact have its rpms varying slightly due to the injectors firing differently between when you are at 14.4 volts and less than 14.4 volts.
I don't have the 6E.tdf, so I cannot confirm if the 165 ecm does do this. It does on the 730 ecm for SD TPI cars.
Old Dec 26, 2000 | 12:47 PM
Glenn,
Thanks for the info,I did'nt know that.
I guess ya learn something new everyday.
Fronzizzle
Mar 18, 2019 08:29 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
