Super Coil Installment
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
The procedure for changing the HEI coil is very easy. You can leav everything in the car while you do it, there'sno need to even take the cap off. Just be sure to put everything back the way you took it out, and to disconnect the negative on the battery so you don't fry anything. It's easy as changing your oil. A new coil will help you keep spark up to higher RPM's It may not make you faster at low rpms but you'll be able to run at the higher ones.
ambainb
Apr 25, 2016 09:21 PM
