Alternator Q.
Old Jan 17, 2001 | 11:10 PM
Wolfcoast's Avatar
Alternator Q.
I just switched from the v-belt to serpentine on my 84 Z28. The alternator has switched sides so I need to extend the wires. Here's my question though. The connectors are different. My old one had two spade connectors. The new one (for a 91 Z28) has 3 tiny blades and 1 bigger one. What do I need to do to be able to hook the alternator up correctly?
Thanx.
Randy
Randy
84 Trans AM LG4, 700R4 T-tops
1984 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
Old Jan 18, 2001 | 09:46 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
First, you will need a connector for the new single serpentine type alternator - GM or Pep Boys may sell them. On the connector for the new alternator, the pins should be marked "S F L P", starting with the large pin on the connector. The only two pins you will need to connect to are the large pin, "S", and the small pin next to it, "F". Pin "F" on the new alternator connects to the brown wire that used to go to pin "B" on the '84 alternator. Pin "S" on the new alternator connects to the red wire that used to go to pin "A" on the '84 alternator.
Tim
Old Jan 20, 2001 | 03:30 PM
Wolfcoast's Avatar
Thanx Tim. Looks like everything is running great. Voltage is around 14.5 ish. Hard to tell with the voltmeter in my car but it looks right on. Finally got the serpentine swap completed. Woohoo!!
Randy
Randy
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
