speedometer
Old Feb 6, 2001 | 03:19 PM
84Berlinetta305's Avatar
speedometer
I have an 84 Berlinetta with the digital dash. The whole dash is screwed up pretty bad anyway, but the biggest hassle is the speedometer. It just sits at 0 no matter how fast I am going. My friend who I bought it from got the tires spinning on ice before he sold it to me, and said that is when it died. He said it only got to 60 or so, then it just quit. What is going on with it? Any help would be greatly appreciated.
[This message has been edited by 84Berlinetta305 (edited February 20, 2001).]
Old Feb 20, 2001 | 05:31 PM
Does anyone know what could be wrong?
Old Feb 21, 2001 | 03:17 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
It could be the VSS at the transmission, the VSS buffer, (yellow box under the driver's side kick panel), the cluster, or the connection between any of the three components. If it went bad with the tires spinning, I'd check the VSS & its drive & driven gears at the transmission, first.
Tim
Old Feb 21, 2001 | 03:34 PM
If it is the VSS, do all cars have them, or i it just the digital dash ones? Also, are they interchangable between v6 and v8? Thanks? How much should one from a junkyard cost?
Old Feb 22, 2001 | 04:38 PM
'90 & later & pre '90 F-bodies with a digital dash have the VSS at the transmission. The V6 & V8 VSS units are the same. The driven gear may be different from another unit, but they are easily interchanged - unless the driven gear on your unit is broken, in which case that is all you would need to buy. Pull the VSS & inspect the drive & driven gears, plug & wiring before buying anything.
Tim
Old Feb 22, 2001 | 05:12 PM
Ok thanks alot. now I might be able to know how fast I am going! What should I be looking for in the Vss etc?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
