Horn buttons on '91 SIR wheel
Old Mar 24, 2001 | 10:35 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
I have to squeeze the hell out of the horn buttons and the horn will only stutter. I tested the horns themselves with straight +12V, they're fine. Is there a fix for this, or am I screwed into buying a new wheel or SIR or whatever? Some s**t-for-brains almost hit me today 'cause I couldn't warn him with my malfunctioning horn.
DR Stevens
Car #1: my ride
1984 TransAm
305HO(L69) 96K & counting
750 cfm Q-Jet/Holley rem.
K&N filter
700R4/Superior shift-kit
and trans cooler
3.42 rear/3.73 blew up!!
underdrive pulleys
Accel HEI Super-Coil
180 stat/hi flow water
pump/Jet fan switch
dual snorkel/'84 ram air
3" exhaust of some sort
partial emissions delete
Car #2: My wife's ride
1991 Firebird/Formula
305TBI(LO3) 99K & smoking
K&N air filter
Hypertech Chip
more engine mods later
"Hey, Uncle Sam!! Where's my f**king tax return??!!"
Old Mar 25, 2001 | 02:09 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I cant help on a fix, but my horn is the same way. I really have to push on the buttons to make it work.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 25, 2001 | 07:44 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
ok some one HAS to post a fix for this B/C mine is the same way
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Mar 25, 2001 | 09:33 PM
Car: 84 T/A
Engine: 305HOL69
Ok, I knooowww you're out there, someone has to know how to fix this....
otherwise i'm going to splice in an old hibeam switch with the latch removed and work my stupid horn by foot!!!
DR Stevens
Car #1: my ride
1984 TransAm
K&N filter
and trans cooler
underdrive pulleys
pump/Jet fan switch
K&N air filter
Hypertech Chip
Old Mar 27, 2001 | 08:17 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
Welcome to '90-'92 Camaro's. I took mine apart because I had the same problem and found that the plastic contacts that go between the SIR cover and the electrical contactw were broken. I didn't have the parts to fix it so I'm not sure if this will help, but I assume it will. Soryy I couldn't be of more help.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Mar 29, 2001 | 10:17 PM
Ragin'87's Avatar
EXACT same problem. My 87 was so much easier... but my 92 is a lot better lookin(just b/c it's not 90% spray paint.. but the 87 was still fast as hell... my L03 is SLOW) I have to squeeze the **** out of the wheel to get the horn to work.. SOMEONE MUST HAVE FIXED THIS..
Anthony
Old Mar 29, 2001 | 11:24 PM
PhantomChamp's Avatar
Rumor has it that the horn buttons were made of weak plastic, which is why they break. I'm switching steering wheels out to a Grant wheel anyways, so I'm not too worried about mine. (this is a 91 Formula)
New horn buttons seem to be the only fix, or coat your old ones with lots of epoxy to strengthen them.
Old Mar 29, 2001 | 11:39 PM
Car: 84 T/A
Engine: 305HOL69
Phantom (or anyone else), do you know if those same buttons are still available? I need to fix these damn things soon, and the wife doesn't like the idea of removing the SIR in favor of a different wheel.
DR
Old Mar 30, 2001 | 09:31 PM
Hulk0202's Avatar
They sell a kit for the horn at the dealer. I dont know the number, but it comes with pieces for both sides. The best way to fix it for good is to put in a new wheel.
Old Mar 30, 2001 | 10:58 PM
I couldn't find replacements anywhere! That's one of the reasons I opted for a new wheel. I suppose a dealer is the best place to look.
Old Mar 31, 2001 | 12:10 AM
Car: 84 T/A
Engine: 305HOL69
Thanks guys, i'll stop by the dealer this Saturday and see if they'll help me.
Where I live, usually they couldn't care less about a guy coming in for 10+year old parts, so I try to avoid them except in instances like this.
EDIT: OK, maybe Moday i'll call if nothing else f**ks up on the car, got stuck doing the fuel pump today.
DR
[This message has been edited by eightTfourTA (edited April 01, 2001).]
Old Apr 3, 2001 | 08:14 AM
ausrs's Avatar
these wheels are a pita
i fixed my horn buttons as i was told that i had to buy a new wheel ....but this is aus
i actually drilled holes in my button "holder" and put small pieces of metal in there and taped them in ...buttons worked ...cost zero ...still pulled the wheel off and installed a momo wheel
Old Apr 3, 2001 | 11:32 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
My air bag and wheel are collecting dust in the basement. Anybody interested if you cant fix yours drop me a e-mail
tpi383@infonline.net
Chris
1992 25th Anniv Z28 W/383 Stroker
536 RWHP 569 FT LBS
(chassis dynoed at Ramsies Perf.)
Check the rest out here
Chiknhawk
Wheels and Tires
Jan 29, 2017 10:19 PM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
luvofjah
Sep 3, 2015 07:08 PM
