Distributor ?'s
Old Jul 11, 2002 | 12:06 PM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
Distributor ?'s
I'm currently modifying my engine and I need some advice.
I have an '87 LG4 and I'm junkin everything on the top end of my engine and putting in the following: Iron vortec heads, Edelbrock preformer RPM intake,700 CFM carter carb,heddman shorty headers with matching Y-pipe,Hooker cat back, Self aligning roller rockers, and so on.
I need help picking an ignition setup and money isn't a problem,
First I need to find a distributor, and it has to bypass all ECM or engine computer crap so what distributor typre should I get,Vaccum advance or mechanical.
I'll also consider an electronic ignition.
My car will also be lacking all emmisions equipment.
I need reliability and power from this sucker so please any input is much welcomed.
Old Jul 11, 2002 | 12:32 PM
Car: '86 Trans Am
Hello (Echo) Is Anyone Out There (Echo)!
Old Jul 11, 2002 | 11:15 PM
Eternal's Avatar
points distibuter!!!!!! :rockon:
Old Jul 11, 2002 | 11:30 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Get a vac. advance HEI. Eternal, I'm sorry but, I have to disagree, points suck.
Old Jul 12, 2002 | 10:52 AM
Car: '86 Trans Am
Ya no points for me.
As for igniton and everything else I'm going to be bypassing all emmissions equipment and eliminating alot of the sensor and the wires whith them.
I'm gonna probably go electic ignition.
Old Jul 12, 2002 | 11:51 AM
Eternal's Avatar
awww, your no fun.....
Old Jul 12, 2002 | 11:14 PM
Car: '86 Trans Am
maintenance I don't mind but I'd rather not.
Old Jul 13, 2002 | 12:43 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Then do it right, Get an entire MSD ignition setup. get a chevy pro-billet distributor, an MSD 6AL ignition, and a blaster2 coil. the pro-billet is mechanical advance, so you set what RPM you want the advance to come in at using a few little springs, and the MSD ignition box will make sure your plugs stay nice and fresh and you will even see a MPG improvment because of it.
I have never seen a better setup, its what I use, my friends use, and everyone I know with a nice engine setup has. Im sure nearly everyone on thirdgen will agree too. Yes, there are other hot ignition setups, but none so proven as the MSD... or easy to hook up. 2 wires to the coil, 2 wires to the battery, and the distributor plugs right into the MSD box. so simple, so good.
Old Jul 13, 2002 | 08:26 PM
Car: '86 Trans Am
Cool!
I looked into it, it's cheap and it's kick @ss so I'm bought.
Thanks.
Old Jul 13, 2002 | 09:36 PM
NTChrist's Avatar
If you haven't already bought the MSD stuff, and you want to save a little money, you could buy a used stock HEI, and treat it to a brand-name conversion package. Pertronix sells an upgrade kit with all sorts of goodies to make your stock HEI like the distributor they sell, for a little over $119. It includes everything like a coil, module, vac. advance canister, springs, cap, rotor, and some wiring. It's called the Flamethrower HEI tune-up.
It'll work well with your carbed setup, you'll save a little $$$, and you can't beat 50,000 volts.
I'm in the middle of the same project you're doing, except with an L03. Everything that's not considered bottom-end is getting tossed for an old school carb setup.
Old Jul 14, 2002 | 12:05 AM
Car: '86 Trans Am
That's the way to go.
Old Aug 14, 2002 | 12:52 PM
Ardels91TA's Avatar
Could you guys give me a hand. This may be the "bonehead of the month award", but I need some help. I'm doin head gaskets, rebuilt head, and headers, so: My buddy came over and took my distributor out one day before I got home from work. He came back last night to help me put it back in, and could not remember how it should go back in. He didn't make any marks on the distributor so we don't know how to put it back in. I have the #1 piston at tdc, but I guess I need to figure out where the rotor should be pointing to fire the #1 cylinder. Needless to say, this buddy didn't get any free beer last night. Anyone who can help me can have his beer though!!! Thank you.
Old Aug 14, 2002 | 04:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The rotor can point wherever it wants, as long as the #1 wire is running to where it points.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
