removing some wiring under the hood....
Old Jul 16, 2002 | 10:52 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
attached is a picture of some things i want to remove, this is a street car, and it will have no a/c, no emissions, and no factory idiot lights/gauges except the speedo and gas guage.
any excess wiring will be trimmed back to the main harness to clean up the looks of the engine compartment
the items in question are circled,
thank you for your input
Old Jul 16, 2002 | 12:47 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
ok looks like what you got circled are:
top left: electric fan relay mounted on rad support next to battery
top right: relay mounted to firewall on drivers side could be either a fuel pump relay or a lighting relay
bottom left: no clue
bottom: looks like part of the heater/ac blower assembly
Old Jul 16, 2002 | 01:00 PM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Bottom left looks like cruise control and charcoal canister stuff.
Rob
Old Jul 16, 2002 | 01:58 PM
Car: 1984 Firebird
Axle/Gears: 4.10
i highly doubt that any of those relays are fans or fuel pump, as the car was originally a v6 and had a mechanical pump on the side of the motor, and it did not have an electric fan,
what exactly is the function of the charcaol canister, and can i get rid of it?
Old Jul 18, 2002 | 11:56 PM
ops32's Avatar
The charcoal cannister is part of the emissions gear.
Rob
Old Jul 19, 2002 | 08:16 AM
JohnnyIROC-Z's Avatar
Car: 1991 T-Top RS
Engine: 305 TBI
The one that is mounted to the radiator support is, I believe, the relay for your lights.
Old Jul 19, 2002 | 11:39 AM
Car: 1984 Firebird
Axle/Gears: 4.10
thats kinda what i am thinkin johnny
Old Jul 19, 2002 | 12:40 PM
84TransAm's Avatar
The stuff on the top right picture [right in front of the driver] are random electrical sensors for the engine. They're not hooked up on my car either.
Old Jul 19, 2002 | 12:49 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
If you don't care about emmissions and not using the puter then basically everything coming from the passenger side harness is computer related. The wires from the drivers side are your essentials.
Old Jul 21, 2002 | 01:32 PM
Car: 1984 Firebird
Axle/Gears: 4.10
thanks for the help guys, i'm going to remove everything that is currently not hooked up, then after we get the car back together, i am going to just unplug things, and if i see no i'll effects, i'm gonna remove it
Old Jul 28, 2002 | 10:05 PM
ZRated85355's Avatar
Today i chopped all of the wires on the passenger side of my camaro. Only a few things were hooked up so before cutting them i unplugged them and there was no effect. It looks so much better with all of that mess gone. And i probobly lightened the fron 10 lbs.
RazorN8
Jan 7, 2022 11:44 AM
mhatfield 14
Aug 15, 2015 10:47 AM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
