starter cranks slow, why?
Old May 28, 2001 | 08:03 PM
camabird's Avatar
Just put in a 87 305 4 barrel motor out of a firebird formula in place of the v-6 in my 82 camaro. When I go to start the car it cranks over very slow and almost won't start, this is embarrasing. I have shimmed it and the whole works. The starter is brand new, I just bought it. Could it be that the engine isn't grounded good enough or maybe the battery isn't big enough. The battery is only about 6 months old, but is for the v-6. I noticed the exhaust y-pipe is fairly close to the starter, could that be it? Should I get a heat shield? Sometimes it cranks over like it should (very rare) but mainly it is very slow. Should I get bigger ground straps for the engine? can anyone help me?
Old May 28, 2001 | 09:03 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Probobly nothing electrical at all, check ur timing, it might be advanced, my 305 cranks slow and sounds like a dead battery almost if I try driving it after a long drive or a hard drive
1986 Trans Am, T-Top, 305 TPI, Flowmaster 80 series. Much more to come in July.
[*]Sound System: Dual 12" Ground Zero Nuclear Series 900 watt RMS subs in custom box made to fit the rear well, Only 500 watts running them though, Pioneer Head Unit and Rockford Fosgate wiring.
AOL screen name= madbiker1
Old May 28, 2001 | 09:29 PM
camabird's Avatar
If it is overadvanced wouldn't it "diesel" after I shut it off? It doesn't do that.
Old May 28, 2001 | 09:47 PM
86FyrBrd's Avatar
Not sure, Mine is fuel injected...my old bird "dieseled" but started easy, maybe it is just slightly advanced...not enough to "diesel" it but enough to make it hard to crank....post a link to this post in the Tech/General board and see what others think..sorry
Old May 29, 2001 | 10:43 AM
JucinGTA's Avatar
Stupid question did u buy a starter for a 305 or a V6? the battery should be a m75, thats pretty much universal for GM cars!!!!Try hookin a battery charger on to it, then start it, does it turn faster? if so u might want to get a bigger battery!!!!
Old May 29, 2001 | 10:07 PM
camabird's Avatar
Hey 86FYRbird, you were right, the timing was off. I got it straightened out and now it starts like it should. I knew that little battery should have turned it over correctly. Thanks a lot man!
Old May 30, 2001 | 09:15 AM
86FyrBrd's Avatar
No problem, glad I could help, just sounded like a fimiliar problem to me
MM2Robinson
Oct 1, 2017 09:16 AM
Grant2k
Apr 4, 2016 08:21 AM
Cleotiz
Sep 16, 2015 08:02 AM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
