fan wont turn off for an hour or 2 after car is off
Old Jun 2, 2001 | 06:35 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hey i heard that this fan is called the "vapor lock" fan.....the hose is like near the carb and goes to a fan on the front right quarter panel......well anyway the stupid fan wont shut off for like 2 hours after i turn off my car.....is it supposed to do that???.....can i just take it off or does it acutally do something??
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
sony xplod cd player,2 12" profile "baja" subs, and a 250 watt MTX amp
$350 for the subs,amp, and box...rattles my car very good!
Old Jun 5, 2001 | 03:42 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
does anyone know????
Old Jun 5, 2001 | 03:54 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
We aren't ignoring you, I personally (and probably most others here) have no clue what you are talking about. I have an '84 Z28 (L-69) with no such fan..... sorry can't help ya.
Old Jun 5, 2001 | 05:29 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
oh
ok
well this sucks!!
Old Jun 5, 2001 | 10:23 PM
TRVLIN99's Avatar
Many of the carbed units suffered vapor lock. This happens when cooler gas from the tank, enters a very hot carb on a hot day. GM supplied these retrofit fans to reduce
carb. overtemp. My 86' Iroc (which is carbed) does not have one, so I do not know the cycle time befor turn-off. Check with any GM dealer. Matt
Old Jun 6, 2001 | 05:29 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
alright
i will!!
thanks for the advice!!!
Old Jun 12, 2014 | 11:10 PM
cxxm's Avatar
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
Re: fan wont turn off for an hour or 2 after car is off
Old post, but I was working on this, so I thought I would add what I found. My car has everything but the hose from the fan to the carburetor.
HARD START,SURGE/HESITATION HOT FUEL HANDLING PROCEDURE #86-650-101 - (Mar 17, 1986)
VEHICLES AFFECTED: 1983-85 'F' Car With L69 Engines (Engine Code G) and 1983 - Early '86 'F' Cars With LG4 Engines (Engine Code H)
Customer comments of vehicle surge, hesitation, and/or stumbles after the vehicle has reached operating temperature, then parked and restarted, (Hot Soak) may be received. This condition is caused by a large temperature difference between the carburetor fuel bowl and the fuel delivered from the fuel tank. This condition can be eliminated by the installation of an auxiliary blower fan, which reduces the temperature of the fuel bowl during a hot soak. The fan is designed to operate at an engine coolant temperature of 106 DEG C (220 DEG F) and stay operational until the coolant reaches 90 DEG C (195 DEG F). This will maintain a fuel bowl temperature of approximately 74 DEG C (165 DEG F).
Listed below are Hot Fuel Handling service kit part numbers:
P/N Usage --- ----- 14094394 Chevrolet 'F' Cars
14094395 Pontiac 'F' Cars
NOTICE TO DEALER: In each kit there is a one page flyer explaining the blower kit operation. Please insure that the customer receives this flyer.
http://www.earlythirdgen.com/forums/...lock+fan#p8768
http://www.turbobuicks.com/forums/wa...ur-2007-a.html
https://www.thirdgen.org/forums/tech...40054-fan.html
https://www.thirdgen.org/forums/elec...6702-what.html
Old Jun 13, 2014 | 08:37 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Wow..I never knew that-weird.
Old Jun 15, 2014 | 12:12 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Just in time...
specialized
Jun 18, 2022 09:26 AM
RazorN8
Jan 7, 2022 11:44 AM
ZsTransAm
Aug 11, 2015 07:30 PM
Kaweh
Aug 9, 2015 02:54 PM
