I think i killed my coolant fan motor, how can i tell for sure????
Old Jun 11, 2001 | 07:05 PM
camaro 22's Avatar
when i first got my car, the guy had a power wire hooked up straight to the battery so everytime i was to drive, i had to hook it up to the battery, and disconnect it when not driving. i got real tired of this, and took it to a radiator shop, and he said the cheapest and fastest way to get around this was to ground the green wire that goes to the relay itself, so that the fan would come on when the car came on, (running constantly) and off when the car is off. now while driving home, i smelled antifreeze, and looked at my gauge and noticed that i was overheating. and shortly after that, started smoking. the fan doesn't work anymore. i put a new relay on, nothing, i hooked it up like it was before straight to the battery, nothing. did i kill the fan motor? how can i fix this or replace this? please i need help bad. i can't drive my car if i'm overheating. please help. thank you.
Old Jun 12, 2001 | 11:03 AM
Camaro_hunter_d's Avatar
can it spin by hand?...reach down and turn it. If its hard to spin its gone...
Old Jun 12, 2001 | 11:46 AM
BlackZee's Avatar
A simple test to see if the motor is getting power is to jump the A-B terminals of the diagnostic connector. This overrides the system and automatically starts the fan. You will be able to hear the fan run. Do NOT start the car with the jumper installed.
Old Jun 12, 2001 | 12:03 PM
It sounds like you have tried to run power to it directly. You may want to try hopping power right from the batt.(its risky and be ready to pull the wire off very quickly) But if the fan will not spin by hand the motor is seized.
Kills to date a 3.1 firebird today 2 stop lights in a row.
95 Grand Am
Serveral Honda's
a freinds 91 Rustang LX(I know its a 4 but he keeps trin')
Planned mods:
Soon coming 3 inch exhaust, 1.6 rockers, High flow 'Verter, and Ignition system. Along with a coplete turbo 4.3 turbo swap planned later this year(hoping to get into the 10's..)
Current mods:
Air box bottom completely removed allowing my K&N to act like an open element filter.
Lower profile tires, 195/55/15 front 205/55/15 rear handles better.
Sterio Sony CD head unit and 9 band EQ, Boston acutics 4x6 dash, Alpine 3 way 6x9 sail, California sounds active crossover, Kroiiler 600 watt amp powering the 'pines and Bostons, 600 watt Jensen powering 2 Rockord Fosgate RFZ1812 subs. And all this cost less then $575...
Old Jun 12, 2001 | 04:32 PM
camaro 22's Avatar
black zee, what a-b thing are you talking about to override the system? the pin thing under the dash, like how you would get codes from? i did try to run it straight to the battery already. that's how the guy who had it before me hooked it up originally, and i tried that way again, and i didn't work. it spins freely with ease by hand. anymore suggestions or ideas just to get the fan to work again even if it is ghetto for now, at least i can drive it somewhere for someone to look at it?. thanks guys.
Old Jun 12, 2001 | 08:16 PM
well here you go. Get an inline fuse holder off a power wire from the battery. Take that wire to a generic relay(8 bucks Camaro fan relay will work fine). Take a wire from the "activate" prong of the relay to a toggle switch, and from the open side of the toggle back to the relay. Run a output wire from the relay to the fan. Then whammo you have a safe fused power supply and can run the fan at will.
Old Jun 13, 2001 | 02:18 PM
dilligaf's Avatar
That will work but if he already ran it directly to the battery and it doesn't come on I'd have to say that its D-E-A-D. It's boneyard time my friend.
D
Old Jun 13, 2001 | 04:27 PM
Stoopalini's Avatar
Your fan motor is fried. You can get a new one at any auto parts store for around $30.
Mine went out not to long ago, and it too smoked. The smoke is a result from the motor burning up.
If you connected it to the battery, and it didn't turn on, that's all the troubleshooting you need to do. Just get a new one ..... they are very easy to install (30min - 1hr)
Thomas.
1992 RS Camaro - Red
305-TBI/5 Speed Manual- 3.08 geared rear
1.6 Roller Rockers / Adjustable Fuel Regulator with high flow pump / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip / MSD ignition
Headers - Flow Master - dual chrome tips
adjustable Coni shocks & struts
eightsixseven
Dec 16, 2024 01:50 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
Leggman1
Aug 6, 2015 04:15 AM
