How hard is it to rewire my car?
Old Jun 27, 2001 | 05:08 PM
TransAm383's Avatar
I am putting the computer back in as well as the Quadrajet and computerized distributor. Problem is, a lot of the connectors that will be needed were just flopping around for a few years and many are melted or broken. I think the easiest solution would to just rewire everything. All the wiring other than the engine bay is good. is it possible to just rewire the engine? Or would that require hacking the replacement harness? My cousin converted his Monte SS to carb from FI and he just took out the "engine harness" as he called it and laid it aside. Are our F-body cars wired similarily? Sorry this was so long and Thanks to anyone whop can help.
Old Jun 28, 2001 | 11:45 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Have fun the best thing to do is go to a junk yard and pull it yourself so you can check as you go along,,,,,,,,,, but what you will find is the ones in the junk yard usally get cut off because it's the fastest way to get an engine out of a CAR, just cut and unbolt the engine mounts, thats how they pull engines, But if all you need is an engine harness you might get lucky, as far as CAR harnesses they usally are hard to find, go to a PICK A PART type junk yard where you get to pull stuff yourself.
Old Jun 28, 2001 | 10:33 PM
Chris Luongo's Avatar
I don't recall any fuel injected Monte Carlo SS, unless you count the '95-up version...but that car couldn't be converted to carburetion very easily either.
Old Jun 29, 2001 | 10:33 PM
TransAm383's Avatar
About my cousin's Monte SS, I never saw a fuel injection setup-I just took his word for it. I think he smokes a lot of dope anyway.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ZsTransAm
Aug 11, 2015 07:30 PM
apie2546
Aug 10, 2015 05:43 PM
squiggy2
Aug 9, 2015 09:30 PM
