I Am *** Of All Electronics!! J/k Check Inside
Old Sep 7, 2002 | 07:01 PM
primer84z's Avatar
im so proud of my electrically ignorant self. i just successfully installed my first ever 5" tach with shift light. i mounted it under the a/c vents and ran the wires under the steering column by the ecm and then under the door hinge and behind the fender to the engine bay. sounds tacky, but you cant see any wires. i didnt want to drill a hole in the firewall so i made do of what i had. none of the wires pinch or bind and they are all hidden. its really nothing to brag about but it was my first time at wiring something up. and before you say something about a tach like that being *****, i found out my stock tach is off by 1250 rpms at idle and it pins at 7k when the autometer tach is at 3.5k. well its still fun to act like im reving to 7k and above. :rockon: anyways, to anyone that felt kind of intimidated by this install, DONT BE. im a electrical idiot and i did it in about 1 hr.
Old Sep 8, 2002 | 10:58 PM
Gta-Paladin's Avatar
you could have pushed it into the engine bay with the throttle cable...
Old Oct 14, 2002 | 09:54 PM
igotslicksNchix's Avatar
help! i need to hook up my tach! i have green, black, white and red wires and no instructions!
Old Jan 11, 2003 | 09:45 PM
CrashedMatrix's Avatar
GREEN is the wire you hook up to the negitive side of the coil normally a white wire
RED is the wire you hook up to power when the key is on
BLACK is the wire you hook up to ground
WHITE is the wire you hook up to your dimmer switch or tap into a dash light bulb somewhere
Old Jan 12, 2003 | 02:07 PM
MdFormula350's Avatar
congrats on the install..
Old Jan 13, 2003 | 03:30 PM
Jza's Avatar
Jza
Wow, this is an old one. I miss Gta-Paladin.
Old Jan 14, 2003 | 11:20 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
...RIP
Old Jan 14, 2003 | 05:59 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
... its good to know that people have not forgotten. May he and his bird find rest in heaven.
Old Jan 20, 2003 | 07:03 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
what happened???
Old Feb 9, 2003 | 12:06 PM
JohnnyIROC-Z's Avatar
Car: 1991 T-Top RS
Engine: 305 TBI
GTA Paladin was killed in a car wreck along with 2 passengers in his maroon GTA. RIP...
Old Feb 9, 2003 | 10:03 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
There is a sticky reguarding it in the transmissions forum. i had just joiuned the forum when the unfortunate topic was brought up. i give my condolences to the friends and family.
GTAman
Mar 15, 2019 11:40 AM
92GTA
Apr 9, 2016 07:39 AM
dibella989
Sep 1, 2015 04:12 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
