160 amp alternator question
Old Nov 26, 2000 | 01:12 AM
camaro 22's Avatar
i have the chance to get 160 amp alternator for $130 plus $12 for shipping and all that stuff. is it worth it?
Old Nov 26, 2000 | 02:06 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Yep.Who makes it? That will help determine the answer.
Old Sep 17, 2001 | 10:30 AM
FiReBReTHa's Avatar
so who makes it???
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Sep 17, 2001 | 10:36 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Stay away from it if it uses the stock housing. There won't be enough of a heatsink to keep it properly cooled. The best choice is get the alternator used in the B4C and Caprice Police cars. It requires an adaptor piece, but it is a direct bolt in and even maitains the same length serpentine belt. This alternator has a larger diameter case and much better cooling. Good luck, Lon.
Old Sep 17, 2001 | 02:15 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If you go with the 140 ampere B4C alternator and bracket from GM, I've found that the bracket needs to be modified slightly (some filing) to fit the alternator. Also, you will need the longer GM rear brace.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Sep 17, 2001 | 09:24 PM
KlayBuRn's Avatar
i got a 190 Amp that fits right into the stock housing, and its made by US Generators, and i havnt had a problem...
Old Sep 20, 2001 | 09:40 AM
FiReBReTHa's Avatar
tell me more klayburn
Old Sep 20, 2001 | 11:26 PM
KlayBuRn's Avatar
the alternator cost me around $350 at the time, and i purchased it from my local car stereo shop, he ran 4 gauge from engine to alternator to ground and all that also, for a grand total of $650 ($100 in connectors), and it held up to my 2 15' XLC's just fine, now, my 2 15' Power DVC's, might be another story
mail me for more i dont check electronics that often...
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
