what are some good spark plug wires?
Old Oct 29, 2001 | 03:26 PM
matthew's Avatar
I was looking to get moroso blue max wires, but if anyone can convince me to get something else I will. I need good RF suppresssion because of my stereo, I also want good performance. Any suggestions?
On a side note, do they come in any other colors besides blue?
yellow 86 Camaro
LG4 700R4
ROH RH 17x9
Bridgestone Potenza RE730 255/45ZR17 all around
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
Old Oct 29, 2001 | 07:29 PM
breathment's Avatar
I have Taylor wires on mine, pretty cheap. like $45, real low resistance. Crane Cams has some that they make called Fire Wire, which are only 400 OHMs per foot, for about $35. both have really good supression
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 30, 2001 | 02:12 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
MSD, Jacobs, and Taylor wires have worked well for me. As was mentioned above, Taylor Spiro Pro wires are a good deal for the $.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Oct 31, 2001 | 11:51 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
From what I have heard the stock ones are not that bad, heck they cost about the same price as a set of average Accel wires.
2.8L V6 173ci
K&N Air Filters
JET Underdrive Pulleys
Old Oct 31, 2001 | 01:26 PM
The resistance per foot of the stock wires is much higher than that of most aftermarket radio supression wires. MSD has the lowest value, followed by Jacobs, and Taylor. Lower wire resistance means less energy dissipated in the wire, which is more important in a CD type ignition system, like an MSD system, for example. Some resistance is required, however, to supress the EMI generated.
Tim
Old Nov 1, 2001 | 11:22 AM
CODY BEHNKE's Avatar
MSD wires high current flow and they look good too.
Old Nov 3, 2001 | 09:21 AM
MY 88IROC ROCKS's Avatar
<FONT SIZE=2 FACE="Tahoma"><font color="#000000"><font size=2>Taylor Spiro Pro's here too. Gotta love 'em. :-)...WooooHoo...I'm finally a "member"!!!!
</font color="#000000"></font size=2>
</font>
[This message has been edited by MY 88IROC ROCKS (edited November 03, 2001).]
Old Nov 3, 2001 | 02:01 PM
thabrotherhood's Avatar
MSD 11mm are quite good I've heard. I haven't hooked up my 8.5 mm Heli-cores yet...doing it this afternoon.
Old Nov 3, 2001 | 10:43 PM
Vader's Avatar
Packard Electric wires. They are available in a variety of resistance ratings, and a variety of insulation depths. Your original wires were Packard Electrics, and probably lasted a sheot-load of miles without a problem.
If you are concerned about resistance, consider Ohm's law, then calculate the effect of that little bit of resistance on a 25,000 volt supply. The only thing the resistance does is supress the residual sparks from saturation of the ignition coil (so that you only get ONE spark per cycle). It always works for me, whereas straight wire always seems to be more of a problem.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 4, 2001 | 01:13 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I cant speak for new MSD wires, but a friend of mine had them on his 87 El Camino. Every time he touched the distributor to change the timing, he would get a nasty shock. Plus he would get radio interference. We took them off and measured them, and the longest wire was 10,000 ohms. He went to the auto parts store and got the same wires I did, 1988-1995 350 Chevy truck 8mm Borg Warner wires. The longest one measured 2,000 ohms, he has little to no radio interference, and no longer gets a shock when he touches the distributor. He even has an MSD 6A and MSD coil too...
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
djmarch
Aug 9, 2015 05:27 PM
