still no turn signal.... help!!!
Old Nov 28, 2001 | 06:57 PM
1982chevycamaroz28's Avatar
okay as iroc&roll told me and what he has said in his other post about turn signals not workin becuz of a buld out. i have another question could the relay for the turn signal be on its way out. becuz ive tryed cleanin the contacts on the bulbs and fiddling around with them but nothing, like when i have the key in and have the left turn signal on it just lights up and stays and ive changed the turn signal bulb in the back a million times with others and nothing and the right side blinkers work but not the left. my friend said that maybe it could be the relay for the blinkers. does the linkers have there own relay under the steering colume and where is it exzactlly becuz i need to get my z28 on the road. ive had it since last yr and the only miles it has on it is only 97.3 miles and well i need it to be inspected becuz im tired of reling on other people. so if any one can help please thank you.
Old Nov 29, 2001 | 01:15 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There is no relay for the turnsignals, only the flasher & if the RH side works OK, then the flasher is OK. If the front LH bulb comes on & the rear LH bulb does not come on, it may be a bad ground connection to the rear socket. Use a test light to verify that there is power at the socket, & if there is, then the socket ground is open. If there is no power to the socket, then there is probably a break in the wire somewhere between the turn signal switch harness & the rear socket. Does the light work in 4 way flasher mode?
Tim
1992 Z28, 305 TPI 5 speed, 12.0 sec @ 114.8 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Nov 29, 2001 | 01:25 PM
yea the 4 ways work but the back right does not light up with the 4 ways on and same way for the turn signal. so u say it might be a bad ground? ill have to check all of the grounds. thanx
Old Nov 29, 2001 | 02:54 PM
okay i checked the grounds and everything is good. but how can i not get power to the back right turn signal but i can get power to the left one. also could the thing that holds the buld could that be shot. well help anyone thanx
Old Nov 30, 2001 | 11:45 AM
tinybfl's Avatar
It really sounds like you have a bad bulb back there. I would try a different bulb. If you are site checking it sometimes they look fine and arent. THats the only thing i can think of. I know its a pain to get the taillights out but might be needed. I dont think its a bad ground because they share a common ground and no lights would work back their if thats the problem. The only way it can be the ground if it is lose going into the bulb socket, which is nice because that wire is so accessable
Old Dec 1, 2001 | 10:56 AM
hi i took the bulb from the right side which works just fine and nothing happened. and then i took the hosing thinger appart to see if anything was lose but nothing was. so does anyone thing it could be the housin that is shot becuz i tryed it with the bulb on the right side and nothing happened and then i took a spare bulb put it in the right side to see if it works and it does. so i dont have any bad bulbs back there, i htink it might e that housing thinger that holds the bulb, i can get a used bunch from the pick-a-part near me. but does anyone thing it could be that becuz the car is almost 20 yrs old. any help thanx
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
