one for the experts, whats this wire
Old Nov 26, 2001 | 01:51 PM
silentneko's Avatar
hey guys,
I found a wire right next to my battery, its yellow and dissappears into the black tubing mess, it has a in-line fuse, and the end has a round metal piece that looks like a screw or bolt could go threw, any ideas, could this be related to my headlights not working?
neko
'87 trans am
car in the making
angelfire.com/fl2/neko
Old Nov 26, 2001 | 05:43 PM
Tonyrodz's Avatar
Transmission: auto
Is it thick gage wire? Sounds like it might have been an old pwr supply for an amp. Ever try to trace it? try to pull it out of the loom--but easily.
Old Nov 26, 2001 | 08:08 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i have seen literally just about every wire that is under my hood, because i reidid alomst all of my wiring and put new tubing over it. i have never seen a yellow wire from the battery. i think its an "add-on" that somebody put on before you had the car.
also, an inline fuse holder isnt GM's style. they like to use the fuse panel. are you sure its not a fusable link?
-brian
1991 Camaro RS
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Nov 26, 2001 | 10:15 PM
silentneko's Avatar
what exactly is a fusable link, just a wire with a fuse in it? and the wire is not that thick of a guage, its not affecting anything but its bugging me.
neko
'87 trans am
car in the making
Old Nov 29, 2001 | 09:48 AM
BillD91RS's Avatar
To my understanding a fuseable link is a spot where the wire is two sizes smaller then the wires it is protecting. That way if it starts pulling to much power the smaller area will melt and not damage the larger wires.
Old Nov 30, 2001 | 08:23 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
that is basically what it is.
it looks like a hard plastic tube that your wites go in. its about the diameter of a pen and usually a couple inches long. usually black too.
when you have too much amperage going through it, it destroys the wire inside.
kind of a pain in the a$$ because if you blow a fusible link, you have to replace the whole damn wire.
-Brian
Old Nov 30, 2001 | 03:40 PM
MotorCityMuscle's Avatar
I have that same wire on my 83 Trans Am and have no idea what it does either.
Old Dec 5, 2001 | 08:55 AM
fordcrusher's Avatar
sounds like you had either an amp or aftermarket foglights. Something that could draw some juice. Maybe even an old pos alarm system.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
