alternator bearing ???
Old Nov 6, 2002 | 05:58 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
hey guys how do I remove the bearings on the alternator from my 85 tpi. On the rear it looks like you just knock it inward. how about the front. it looks like the front bearing is pressed onto the shaft. I need to strip my alternator so I can powder coat it.
Old Nov 8, 2002 | 08:23 PM
Andy Bush's Avatar
Once you have the pulley off and the shaft out from the end frame, there should be a screw holding a retainer plate on the inside. Remove the screws and the plate, then the bearing should be removable with a push from the outside.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
gord327
Oct 3, 2015 01:25 PM
raymondandretti
Sep 27, 2015 06:43 PM
