How to check TPS voltage?
Old Nov 29, 2002 | 05:51 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I have a 91 z-28 with a TPI. How do you actually go about checking the TPS voltage? thanx guys, and gals.
Old Nov 30, 2002 | 09:17 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The TPS has 3 wires. Use a decent multimeter and probe the CENTER wire with the positive meter lead and the ground lead of the meter to a good chassis ground. I use a straightened paper clip to get through the rubber insulator to make contact with that center TPS lead. TPS must be plugged in as normal, it should read approx .55 volts. Some of the later ECM were self setting meaning no adjustment was needed but I am not sure what year that started.
GTAman
Sep 21, 2015 09:57 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
