Probably an old topic but new to me...
Old Dec 9, 2002 | 11:31 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
I am interested in removing the ECM (computer) from my carbed '83 T/A, and using a non-computer HEI distributor (2-wire, instead of 3). I also want to retain all of the emission-control equipment (Cat, EGR, Air, etc.), but I need the "Check Engine" light to come on when the ignition key is switched on, and go off after the engine is started. Has anyone done this?...
Old Dec 11, 2002 | 10:23 PM
racerx004's Avatar
Sounds like your in a bind.
You need the computer for the check engine light to work.
As for removing the distributor and what not, you might want to try the tech general section on here.
They may be able to tell you how to get around the wire problem on the distributor.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Abubaca
Nov 5, 2016 12:22 PM
drumstixer
Sep 29, 2015 03:02 PM
corey8084
Sep 17, 2015 02:56 PM
greenyone
Sep 8, 2015 08:41 PM
