Location of battery disconnect switch.....
Old Dec 10, 2002 | 06:21 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Where can I mount my battery diconnect switch w/o drilling thru the tail light or the bumper on my GTA? I was wondering if it was possible to cut a hole behind the license plate and mount it back there. That way I could just take off my tags at the track and be ready to go.
Old Dec 13, 2002 | 08:22 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
if you race the car, there are rules on where you can locate the switch. im not sure what they are but you might want to check your local tracks rules
Old Dec 8, 2005 | 11:46 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
does anyone have any more ideas of where would be a good place to mount the switch??? our cars dont give much room to mount it...
Old Dec 8, 2005 | 09:47 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
most of my friends and i mount it through the tail light housing and drill a hole in the rear firewall. i suppose you could drill a 1/4 hole and run a "push off" style handle out the back. honestly where the license plate is located there is a large housing there that holds the electric pull down hatch and i doubt there's much room to mount it.
Old Dec 9, 2005 | 05:45 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
if you run a fuel cell and no longer have the stock tank the fill cap location seems ideal. i don't know what your running or what type of racing you do... but thats where i would put it (if legal).
how about protruding from below your rear bumper? that would not cause any permanent body disfigurement.
Old Dec 9, 2005 | 07:15 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
A firebirds license plate is located in the bumper down low.
If possible, that's where I'd mount it.
Old Dec 11, 2005 | 10:33 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Location of battery disconnect switch.....
this is some thing that i want to try in the future.
i want to mount a flip down license plate bracket from a camaro and mount the disconnect behind the license plate .
Old May 23, 2006 | 09:00 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
i finally got mine mounted (Camaro). Went right behind the plate with a little "modification" to the electric pull down bracket.
I also had to bend a tab (one that covers the spring) out on the lisence plate bracket itself because it wouldn't close enough. It still doesn't close all the way but it closes enough to look like nothing is different.
Now nobody the wiser will F with the switch on the street and I can flip the plate down at the track. For extra vandal protection I will just remove the switch handle and leave it ON if need be.
Old May 24, 2006 | 06:57 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
heres a link from older thread....https://www.thirdgen.org/forums/body...ll-switch.html
GTAman
Jul 3, 2024 07:29 PM
MM2Robinson
Oct 1, 2017 09:16 AM
64goatman
Sep 9, 2015 01:09 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
