Where did you mount your master battery shut off switch?
Old Jan 11, 2005 | 10:45 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Post pics if possible. Mounting battery in rear and looking for ideas on where to place the master cut off switch.
Old Jan 11, 2005 | 01:11 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Right behind the license plate. When I get home if I remember, I'll take a few pics for ya.
Old Jan 11, 2005 | 02:03 PM
Car: 1971 Camaro
Engine: 427
Good idea. Would love to see pics, if you can take some of the inside, where it goes through that would be of great help! Does it cause the license plate to stick way out?
Old Jan 11, 2005 | 05:07 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i put mine in the passenger tail light
Old Jan 12, 2005 | 12:57 PM
CraZ-28's Avatar
Car: 1991 Z-28
Ok, here is what it looks like from the inside with the plastic covering it. Also note, I have the power motor for the deck lid so that is why the switch is in the location that it is.
Attached Thumbnails Where did you mount your master battery shut off switch?-master-cutoff-switch-003.jpg
Old Jan 12, 2005 | 12:59 PM
CraZ-28's Avatar
Car: 1991 Z-28
Here is where the switch is located from the outside. You will need to trim the tail light a little bit. When I get a new one, I'll make mine look better.
Attached Thumbnails Where did you mount your master battery shut off switch?-master-cutoff-switch-002.jpg
Old Jan 12, 2005 | 01:02 PM
CraZ-28's Avatar
Car: 1991 Z-28
This is with the plate up.
Attached Thumbnails Where did you mount your master battery shut off switch?-master-cutoff-switch-001.jpg
Old May 23, 2006 | 09:15 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I wanted to make sure mine wasn't visible with the plate up so its just like that except mounted slightly to the right!
Old May 24, 2006 | 07:04 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
https://www.thirdgen.org/forums/body...ll-switch.html
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
