What turns on when car is off?!!?!?
Old Feb 24, 2003 | 10:57 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
im trying to find a wire that gets power when i turn the car off, but doesnt have power when the car is on.... i cant find ANYTHING.
im wiring up one of those scanner things and i want it to turn on when i turn the car off and i dont want to wire it to a switch.. please help.
Old Feb 25, 2003 | 02:52 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
i donno... you could wire up a normally closed relay to an accy. wire so when power is applied the relay opens (no flow of current) and when the car is off (no power to the relay coil) power will flow to the scanner through the battery or something...hope you understand
Old Feb 25, 2003 | 06:03 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Dan is right, there is no voltage available the way the car is wired. You either have constant 12, or key on 12. You need a relay. Use a double pole relay and make sure that the relay coil is de-energized with the key off. Relay coils can draw anywhere from 50-300ma and drain the battery if the cars sits a day or two.
Old Feb 25, 2003 | 05:23 PM
Car: 1984 Z28
so lets say, for example, that i did wire it to a switch and could turn it on when i turn the car off, it has like 8 led lights or something.. if i left it for like 10 hours would my battery die?
Old Feb 25, 2003 | 05:57 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
humm I dout it alarms with LED's don't drain the battery. But it would depend on what kind of LED's you use ie how much power they are using, I guess. Anyone got a real answer? TTT
Old Feb 25, 2003 | 05:59 PM
92Transam's Avatar
TTT
Old Feb 25, 2003 | 06:06 PM
Car: 1984 Z28
well you can wire it so when you have an alarm it turns on, and on the package it did have a way to do it without
Old Feb 26, 2003 | 06:00 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Most devices will list what the average current draw is, or you can measure it if you have a multimeter. Typical car battery is around 75amp/hours. Meaning this, you can draw 75 amps for 1 hour, or 1 amp for 75 hours before the battery is considered discharged. GM specs parasitic drain for most post 95 cars at less than 12ma. An average stand alone LED figure somewhere around 5 ma, times 8= 30 ma. Not a problem. e.g., a 500 ma or half amp parasitic draw would give you roughly 150 hours, a 30ma load 5 times that. Hope this gives you some help.
Old Feb 26, 2003 | 05:35 PM
Car: 1984 Z28
i assume ma is milliamps. i know nothing about that kind of stuff.. the only thing i can do is wire a stereo.. ,
i guess i could just charge the battery and leave it on for a night and check the next day to see if the battery is full enough to start the car.. i have it parked for the winter so i might as well.
Old Feb 26, 2003 | 07:56 PM
dans82bird's Avatar
Engine: 302
if you wanna take the easy way out just wire it into the always hot stereo wire
Old Feb 26, 2003 | 09:55 PM
Car: 1984 Z28
but then it will be on forever... our is there a wire that grounds when the car is off, and doesnt when the car is on..?
Old Feb 27, 2003 | 12:30 AM
dans82bird's Avatar
Engine: 302
there is always a ground on the car... you are looking for a positive wire that will be on when the car is off..... there is none that I know of.... what I would do:
get a normally closed relay (current flows through the contacts in the normal position; flow is interrupted when power is applied to the coil) and wire the coil to the accessory wire (therefore turning the relay on when the car is on and turning off the light) now when the car is off current will flow through the relay to the light...pretty simple and should only take about an hours worth of work for the novice.... if you need any more help pm me
Old Feb 27, 2003 | 05:34 PM
Car: 1984 Z28
thanks dude
Old Mar 1, 2003 | 01:19 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
The wire you want to go to the relay coil is the radio wire, not the accessory one. The accessory wire is always hot, because it also powers the courtesy lights and the memory for the radio. That one I think is orange (this is according to chilton's so it may be different, but this is for 84). The radio wire is pink/blue. Run that wire to the coil on the relay. Then run one pole of the relay to the accessory wire and the other to the LED scanner. You can use the ground wire for the stereo to ground both as well.
As far as the draw, I wouldn't worry about it. I've left the LEDs in my vents on all night, as well as the undercar neons and had no problem starting it up in the morning.
Old Mar 1, 2003 | 01:24 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Here is a wiring diagram, sorry for the lousy drawing. Just go to radioshack and tell them that you want a 12 volt N.C. (normally closed) SPST relay.
Old Mar 1, 2003 | 03:41 PM
Car: 1984 Z28
thanks! ill head over to radio shack today!
is radio shack also in the states?
Old Mar 1, 2003 | 10:23 PM
92Transam's Avatar
Yes its everywhere! *runs from radio shack * AHHHHHHHHHHHHHH THEY ARE AFTER ME! lol
Old Mar 2, 2003 | 02:09 AM
dans82bird's Avatar
Engine: 302
the contact (relay) in that schematic should be closed; not open in current status (no v+ to the coil)
Old Mar 2, 2003 | 02:44 AM
dans82bird's Avatar
Engine: 302
if you need some relays I have tons... just pay shipping if you wanna few
Old Mar 2, 2003 | 01:26 PM
Car: 1984 Z28
i hate electronics. i understand nothing. but i do understand sort of what you are telling me to do i guess.
Old Mar 2, 2003 | 02:01 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
They will have relays that only have four contacts on them. On the back of the package there will be picture just like the ones drawn above. Two contacts are for the coil and two are for the switch. Then just connect it like in the diagrams. Radioshack even has ones that are specifically for cars that come with seperate harnesses, but those are made for a large draw device. For something like the LEDs, you can use any 12 volt relay. But if you don't feel comfortable trying to solder wires onto the contacts, then one with a seperate pre-wired harnes may be the better way to go. Why don't you just print out this thread and take it into the guys at radioshack. They should be able to help you find the right relay.
Old Mar 3, 2003 | 08:37 PM
Car: 1984 Z28
wow i never knew you could do that!!! and all this time i wasted cutting and pasting so i wouldnt have to print color!! THANKS!
Old Mar 4, 2003 | 09:21 PM
dans82bird's Avatar
Engine: 302
:sillylol:
good luck man
Old Mar 5, 2003 | 08:05 PM
ajm_shorty's Avatar
Sounds to me like your car is from Hell
Old Mar 5, 2003 | 10:00 PM
Car: 1984 Z28
lol lol lol
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
