trunk release
Old Mar 25, 2003 | 04:00 PM
Kaps's Avatar
trunk release
Anyone know a way to diagnose the trunk release? like what to look for, seems like everything back there is hooked up and the button isnt broken when I hit it I hear it click, but isnt popping the back... Dont know too much about it...
Would it be cheaper/easier to get a diffrent aftermarket release installed?
I NEED a trunk release, the lock was ripped off and the metal back there ripped up pretty bad, so I just want to cover the damage with a metal plate and get a new plastic cover and call it a day for now...
ANY HELP IS VERY MUCH APPRECIATED!!:hail: :hail:
Old Mar 25, 2003 | 07:45 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
The solonoid may be bad. Check for power at it when the button is pressed. Did it just stop working or did it do it after you worked on it?
Matt
Old Mar 25, 2003 | 08:45 PM
Kaps's Avatar
It hasnt worked in months, just wasnt important until now, where is the solinoid, and what does it look like if its in the back by the pull down motor, thanks!!
Old Mar 27, 2003 | 06:44 PM
Matto'85TA's Avatar
The soloniod is on the hatch motor. it has one heavy cable coming from it from one end and that cable attaches to the lock mechanism. It should have 1 or 2 wires coming from it.
Old Mar 27, 2003 | 09:26 PM
Kaps's Avatar
ok, how do I test the silonoid and where would I get one if its bad, I dont think Kar parts would carry that....
BTW, The car was broken into in a lame attempt to get my subs and amp, I didnt do it... lol
Old Mar 28, 2003 | 05:48 PM
Matto'85TA's Avatar
Apply 12V to the solinoid. If it operates, its good. Talk to Lonsal about hatch parts. He sells them. Any of the thirdgen stores listed on the site should have one.
Old Mar 28, 2003 | 06:18 PM
Kaps's Avatar
thanks alot man:hail:
Old Apr 1, 2003 | 10:52 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
If you have HITHERE 5sp. make sure the HITHERE-brake is set
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sylentnite
Sep 9, 2015 02:55 PM
