this is just too odd???
Old Apr 25, 2003 | 11:55 PM
Kandied91z's Avatar
i don't know who to ask, you must read this! i know it isn't thirdgen related but i'd appreciate it if the mods would leave it for at least a day. sorry, but i don't know where to go.
my right turnsignal comes on when i hit the brakes. i've checked all fuses and bulbs and they are in good condition. there are no indications of an improper working turn signal, however when i hit the brakes the right turn signal indicator on the dash lights up dimly?
what could cause something like this? it's a 96 ranger (typical of ford).
Old Apr 26, 2003 | 02:15 AM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
You're right, that is a weird problem. There's some linkage for the brakes under the dash, maybe a wire got stuck behind it and when you hit the brake it pulls on that wire. Hopefully someone else can help you better, but thats the best I can do right now!
Old Apr 26, 2003 | 03:02 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Which ever side is sticking, check the main brake lamp for that side. I have a ford too, and I have the same problem when one of those dual fillament light bulbs goes nuts. Even if the bulb looks good, replace it and see what happens. If not, check the flasher, the wiring is too staight forward for this to occur unless you (I am implying any one who worked on the car) messed with the under dash or tail light wiring. If you have trailer connections in there, check and make sure they are wired correctly.
Old Apr 26, 2003 | 01:31 PM
Kandied91z's Avatar
true, i checked the bulbs and switched them around.........didn't just replace them though. all wiring in the truck is stock. haven't touch anything. i've been trying to find a "flasher" relay much like what we have on the thirdgens with no luck.
i agree with the wiring being individual which is odd why the bulbs are doing this. everything is working so it can't be a fuse so i assume that it's either a relay messing up somehow or something is causing the wires to connect with each other.
i'm at a loss.........time to trade her in. :lala:
Old Apr 28, 2003 | 07:48 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Does tehe turn signal outside also come on when you press the brake? If so, ceck the ground on that side.
Old Apr 28, 2003 | 07:54 AM
lockdude's Avatar
Your brakes are wired directly through the turn signal switch whenever there isn't a separate bulb for the two, and your swicth is dying. Time to put in a new turn signal switch.
Old Apr 28, 2003 | 08:49 AM
jeffs82z28's Avatar
As was mentioned before, check your grounds and make sure they are clean and tight.
Less work than a T/S switch, right off the bat, and cheaper also.
Old Apr 28, 2003 | 12:20 PM
Kandied91z's Avatar
there is a separate light for both so that's why it seemed odd. i'm going to check the ground, replace the bulb and get back with you today. thanks everyone!
Mark_ZZ3
May 24, 2018 01:02 PM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Warlocksirix
Sep 3, 2015 12:26 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
