Fans Staying On When Cold
Old Apr 26, 2003 | 08:53 AM
RaysIrocZ88's Avatar
HEY GUYS MY DUAL FANS ARE STAYING ON WHEN IT IS COLD CAULD IT BE THE RELAY OR A SENSOR OR ?????
Old Apr 27, 2003 | 08:05 AM
HeavyBreathinRS's Avatar
Car: 1990 RS
Put ignition switch in run.
Disconnect Coolant fan relay connector
Connect test lamp between terminals of connector at the BROWN wire and the DARK GREEN/WHITE wires.
If lamp lights - check DARK GREEN/WHITE wire for short to ground...if it shorts fix it
If lamp does not light, replace coolant fan relay.
With thanks to my shiny new (used) factory service manual...
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
64goatman
Sep 9, 2015 01:09 PM
scottmoyer
Sep 7, 2015 07:06 PM
