Wiring for Headlights
Old May 23, 2003 | 10:42 AM
FLYNLOW92rs's Avatar
Is it possible to have my headlights put on a switch??
I would run the wires through a fuse, then a switch which i can mount inside the car??
I want to change to 9005/9006 headlights, and just figured i would run the positives and negatives straight from the connectors to a switch so i don't have to mess with the stock harness??
Will this work??
Any help is appreciated....
Old May 24, 2003 | 10:20 PM
ttt
Any ideas??
Old May 25, 2003 | 01:11 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Wouldn;t it be a whole heck of alot easier just to solder into the existing headlight harness'? It would save you alot of trouble. As long as the lights you're putting in don;t overpower the existing system, I'd just do a little solderin/splicing.
Old May 25, 2003 | 06:40 PM
the number of wires on the connector don't match the number of wires that lead to the STOCK wiring harness....
Old May 25, 2003 | 10:58 PM
EYEROCK89's Avatar
Car: 1989 IROC
Do you have a diagram of the wires for the 9005/9006 bulbs and what each wire does. You may be able to figure something out.
Old Jun 1, 2003 | 08:46 PM
Ok, i got the problem figured out, thanks guys...
One more question, WHERE can i find the following fuse that is circled below?......
Old Jun 1, 2003 | 11:35 PM
Vader's Avatar
That is a fuse that YOU have to provide, along with the relays that handle the extra load of the higher wattage lamps. You should be able to find it an any parts store.
Old Jun 2, 2003 | 12:47 PM
So where along the STOCK wiring harness do i insert the fuse???
Do i have to put a seperate fuse for each headlight, just to be on the safe side, or in the STOCK harness do they meet up somewhere......
Old Jun 8, 2003 | 09:04 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
would try and place fuse somewhere towards beginning of the circuit in the 12v feed wires
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
Jk_Under
Sep 2, 2015 10:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
stalkier
Aug 13, 2015 12:59 PM
