HELP! all of a sudden my car is extremely slow!
Old Jun 10, 2003 | 10:29 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i was just driving to the store the other day and when i got on the gas a little bit there was no acceleration. it's like i'm driving around in a 110 hp z28. the motor sounds perfectly fine and i checked everything i could think of and everything seems fine. what can this be? i can only suspect it has something to do with the electrical stuff. i was thinking the coil or some other part of the ignition. i was wondering if anyone else out there had any problems similar to this and if yes then how did you fix it? thanks
Old Jun 10, 2003 | 11:01 PM
Ovrclck350's Avatar
clogged cat
Old Jun 10, 2003 | 11:34 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Yeah I would check your electrical. Make sure your running on all cylinders. Do yourself a favor and give it a tuneup.
Old Jun 11, 2003 | 06:04 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
I agree, if the cat plugged that's exactly what happens. If he was missing even a cylinder he would know it. Also check the distributor, maybe it was loose and moved causing a timing change.
Old Jun 11, 2003 | 08:16 AM
shaggy56's Avatar
Car: 71 Nova
I would check that anyhow. I have seen people run a car with cylinders not firing and its really unnoticeable. Sheesh I even recall a time when i noticed one of my wires wasnt even connected. I tell you what there was no sure sign it was unplugged just the fact i noticed while under the hood. I tell you what I picked up power after that. I speak from experience. I would think to look for a simpler solution than the clogged cat and work from there. Then if everything seems to be in order than take that route.
Old Jun 11, 2003 | 11:14 AM
92TPIZ28's Avatar
Engine: 355
i'm thinking it might be the timing. i've noticed that when i engine break there is a lot of popping in the exhuast from backfiring and i assume that is from bad timing. does that make sense? or is it something else. thanks for all your replies.
Old Jun 16, 2003 | 11:35 PM
Guest
Guest
Posts: n/a
i 2nd that.
Old Jun 16, 2003 | 11:46 PM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
Originally posted by My86Firebird
i 2nd that.
Im going to have to 3rd that motion!
Old Jun 17, 2003 | 07:16 AM
Guest
Guest
Posts: n/a
All in Favor Say I? .....
hehehe
Old Jun 17, 2003 | 04:44 PM
xChRiSx's Avatar
yep my car was being stupid and the cat fixed the slow part. i think i may need a new ecm though
Old Jun 18, 2003 | 06:34 PM
92TPIZ28's Avatar
Engine: 355
well i have good news and bad news. the good news is that i found the problem. it was the timing. it was bouncing from 0 to 4 degrees which is not great for my setup. i advanced it to 12 degrees and WOW! i have been missing out. i thought i did something wrong in the swap cause i was not achieving the performance i was hoping for, but with the timing at 12 degrees she really opened up. this was last wednesday and i was very happy and excited with my car. BUT the bad news is that i went out friday night to race one of my friends in his dad's BMW 745 which is somewhat respectible. i couldn't resist the offer so i went out and raced him. we raced till about 115 and i had a half of a car length on him with a LOT of wheelspin for me off of the line and minimal wheelspin for the BMW. well to make a long story short on the way home i noticed my car seemed a little funny. then worse. when i have the throttle down more than 30% it starts to jutter and seems like the fuel is going on and off repeatedly, making me angry. i got to my friends turned it off, let it cool down and then went to start it to go home and it didn't. my friend jumped me and i drove home with out ever letting my foot off of the gas cause it kept wanting to die at idle. i finally got it home and went to bed. saturday i went out to look at it. i noticed a hose wasn't plugged in at the back of the plenum so i plugged it in and she started up with a little trouble, but at least she was idling. i took it for a test drive and that juttering is still there, damn i thought it would of been simple to fix so i assume (a very big assume) that it is just the timing again. so i went out and bought a timing gun cause the first time i took it to my local mechanic that i've known for a long time and he checked it and changed it for me, so i figured i'll do it this time. but i have no clue how to do it. i did searches and found out how, but it just doesn't make sense to me so i figured i'd just advance the timing anyway without checking to see what it was at. so i loosened the bolt and went to go turn the distributer counterclockwise but i couldn't cause there was no more slack in the plug wires. so i just moved it just a tiny bit and tightened the bolt back and now my car doesn't start at all. i read after i did this that before moving the distributer you need to disconnect some wire that's brown, well oops i didn't do that and i'm wondering if that's the reason it isn't starting now. well i was out of town the last few days but now i'm back but it's raining real bad right now so i guess i have to start from scratch tomorrow. do you guess also agree with me it is the timing again? i really hope so cause i don't want for it to be something that's going to cost a lot of money and time to fix. well i'll keep you guys posted, thanks.
Old Jun 19, 2003 | 12:36 PM
shaggy56's Avatar
Car: 71 Nova
hmmmm
Old Jun 21, 2003 | 11:14 AM
92TPIZ28's Avatar
Engine: 355
any other input? please i need some ideas, thanks
Old Jun 21, 2003 | 04:56 PM
Guest
Guest
Posts: n/a
you have the timeing WAY TO far advanst. (sp) back it off. and check the timeing. you don't want it to be to far or you can burn a hole in the piston (if its cast) also do you have a HEI system with vaccum advane?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
86Base
Aug 8, 2015 01:34 PM
