"sensor" on air cleaner housing
Old Jun 27, 2003 | 03:50 PM
The Beast's Avatar
Changing the air cleaner filter the other day and noticed this "sensor" attached to the front of the housing... What this for?
Old Jun 27, 2003 | 04:43 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
whats it look like, sometimes MAP sensor was attached to air cleaner bases, on some engines and some years
Old Jun 27, 2003 | 09:01 PM
The Beast's Avatar
Well it looks like a sensor. I thas the brass wrench fitting with I believe one wire coming off it. The other side goes through the air cleaner canister and is white w/ open slits near the end. Aprox 1/8 to 1/4 in in dia.
Old Jun 27, 2003 | 11:46 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I know this probalby isn't accurate/correct but, on TBI cars (only?), there is a sensor in the air filter housing which is (for the life of me I can't remember the name) the, I want to say, MAT (manifold air temp) sensor. For some reason I don't think that correct though (too lazy to go look it up too)
I have one on my 91 TBI and just drilled a new hole on the air cleaner base as close to the TB as I could. No ill effects so far.
Old Jun 28, 2003 | 01:03 AM
25THRSS's Avatar
IAT sensor i believe.
Old Jun 28, 2003 | 10:06 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
if you have the dual air filters on it, it is the MAT (manifold air temp) sensor, i had mine go bad last week. she aint the cheapest thing in the world either, lol
Old Jun 28, 2003 | 01:27 PM
The Beast's Avatar
Not sure If I have duals. There is the round canister type filter on the front left side of the radiator ( looking from front to back) and then there is anouther rectangular plastic "housing" that sets on the top back side the radiator. Although I have never read/seen anything that states that is a cleaner too.
86IROC112
Sep 7, 2015 01:37 PM
db057
Aug 22, 2015 08:17 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
