What is this ???????
Old Jul 19, 2003 | 05:27 PM
Matrixra's Avatar
Hello,
I need to identify this item in my engine bay. It is located on a wire near my battery. When I open it, it has a thin metal spike in it. I have never seen this in any car! My car is a non starter with the fuel pump not priming and my local garages get scared when you tell them it is an American car.
There is no fuse that I can see for the fuel pump in the fuse block either?
Many thanks in advance.
Steve
Old Jul 19, 2003 | 05:45 PM
Tyler-88's Avatar
if the fuel pump doesnt prime. you should get the fuel pump to activate after cranking the engine maybe 6-8 times until oil pressure builds up. the fuel pump relay is on the drivers side against the firewall. check the connections and maybe replace the relay.
Old Jul 19, 2003 | 05:55 PM
Matrixra's Avatar
Cranking it does not make it start :-(
This all started when I tried to jumpstart it. All of a sudden white smoke started to come from the back of the engine bay in the middle by the ( I believe ) dist. cap?
This stopped when the battery jump leads got taken off.
The car does start when I spray easy start into the injector ports and stops when that is used up.
As far as I know, my fuses are all okay.
I wish I knew what that thing is in my picture!
Again, many many thanks!
Steve
Old Jul 19, 2003 | 09:19 PM
1986redbird's Avatar
the connector in the pic looks like the power feed to the computer, at least it looks exactly like the one in my car.
Old Jul 20, 2003 | 01:05 AM
3gc's Avatar
3gc
Car: Z28
I think that is the power wire to the ecm. Check to see if you can turn your fuel pump on with the aldl port, i believe you apply 12 volts to terminal G but you should double check with a search on the board. Also check to see if your getting an injector pulse. If not check to see that the computer is gettin 12volts. If it's not look for a fuse in a capsule and check that.
Old Jul 20, 2003 | 06:43 AM
Briansz28's Avatar
Matrixra- That looks like a fuse holder. You say there was a metal spike in it? Not a fuse w/ glass and metal on the ends? Could it be possible that the fuse blew and some one put a piece of metal to jumper it? If so, there is a short somewhere that would make the fuse blow.
The white smoke by the distrubutor- what does it smell like? Burning oil- gas? or acrid electrical smell? If its the latter smell, I would guess the solid fuse (if thats what is in your fuse holder) is letting enough amperage thru to fry the guts of the distributor.
Get a new fuse. If it blows right away there is a short somewhere. If it is the power feed to the ECM, post a message about it on the ECM board. They might have some more info. Hope to have been of help!
Old Jul 20, 2003 | 08:44 PM
jess's Avatar
Car: 85 Z28
Engine: POS 305
what is it
Hey Man that is your power wire to your ecm
Old Jul 21, 2003 | 01:16 AM
Tyler-88's Avatar
smoke coming from behind the engine sounds like it maybe the fusable links. id check thoes. they come off the starter. their such a bitch to get at.
Old Jul 21, 2003 | 01:17 AM
Matrixra's Avatar
Great! Thanks for your help with that one guys.
I will try the things suggested and try and get it started again.
Thanks again.
Steve
