Where does this wire go to?
Old Jul 29, 2003 | 06:31 AM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Im installing a power release solenoid so I can pop open my hatch, but where does the wire go from the solenoid to the dash? or switch or something. Heres what the solenoid looks like the one I just bought.
Old Aug 6, 2003 | 08:13 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I think you just have the momentary switch in the console that is a break in the + line... but I'm not totally sure on the wiring!
Old Aug 7, 2003 | 03:27 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Are you saying that you're installing a hatch release on a non-equipped car, or are you replacing one that is equipped???
If installing on a non-equipped car, just splice the switch to a CONSTANT (hot) wire (not a key-on wire).... this way you can pop the hatch with the key out....
Old Aug 7, 2003 | 04:00 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
...but so can anyone... IE thieves!!!
Old Aug 7, 2003 | 04:04 PM
Unfortunately, that's very very true!!!
Old Aug 7, 2003 | 04:17 PM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
the factory switch is located at the rear of the center console between the poweer window switches. factory switch uses a constant 12 volt source, but it runs through a switch built into the shifter plate, so you can not accidently open the hatch when the car is in gear
Old Aug 7, 2003 | 05:02 PM
warrior_91's Avatar
Car: 86 T/A
Yes everyone, Im installing on a non-equipped car. My car did not come with the hatch release feature. Thanks for the help everyone.
Old Aug 9, 2003 | 05:16 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
don't forget a fuse, 5a should be fine 16 gau. wire
Old Aug 9, 2003 | 10:21 AM
badjuju342's Avatar
Engine: ls1
install an on-off switch wherever you want in car,connect 1 side of switch to 12v battery source under dash,connect other side of switch to release soleniod wire in question.the body of solenoid is ground so be sure that bolts are tight&it is mounted directly to car body's metal.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
