brake lights
Old Jul 31, 2003 | 08:00 PM
pskel350's Avatar
brake lights
whenever i step on the brakes, the front parking lamps come on, along with the brake lights.....where do i even start looking for the problem?
Old Jul 31, 2003 | 08:46 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
not sure but sounds like maybe a crossed wire somewhere
Old Jul 31, 2003 | 09:21 PM
pskel350's Avatar
thats what i think to0, but im just wondering how it got crossed. i havnt messed with those wires at all, and it just started today. and also the wiring harnesses go to oppisite ends of the car.
i have no clue where to even start looking. any ideas?
Old Jul 31, 2003 | 09:32 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
IMO, I would investigate that rear lamp harness. Since it's exposed to the elements, it would be the 1st place for wire insulation to deteriorate and possibly come in contact with the park lamp wiring. It could also be something as odd as a fautly bulb. The filiment could have broken and is now laid on the park lamop filiment causing it to charge the park lamp circuit. That's a long shot theory but, it's not totally impossible.
Old Jul 31, 2003 | 09:35 PM
Engine: 283
must be that ghost thats in my car
had a problem with my blinkers...you probably seen the post "one strange azz question"....hasnt happen since then
my suggestion is to put "Holy Oil" on your car (like what i need to do) get rid of that ghost----lol
i dont really know where you could start looking..not too good with electronics sorry!!!
Old Aug 1, 2003 | 02:47 PM
pskel350's Avatar
i think it might have to do with a bulb, since i just had the wiring out and checked over it 3 months ago when the car was painted.
its probably the same ghost that is stealing all my gas :lala:
im about to the point where i am just going to re-wire the whole car
Old Aug 1, 2003 | 04:19 PM
1986redbird's Avatar
sounds like the old "wrong bulb in the wrong socket" problem, did you just replace any bulbs in the brake lights?? check all the bulbs in the rear of the car, if you got a single element bulb in where a dual element goes it will cause the very same issues. just look in the socket (after removing bulb) bottom and see if there is one metal stip or two, then compare the bulb to it, if the socket has two strips then the bulb should have two little "****" sticking from the bottom of it.
Old Aug 6, 2003 | 01:54 PM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
the last post was dead on,you've probably stuck an 1156(single element bulb) where an1157(dual element bulb) goes .the 1156 has one "tit" and the 1157 has two.if you put an1156 in an1157 socket you just "fused"the parking light and turn signal together doing exactly what you say the car is doing now.you can look at inside of bulb if it has two "horns" connected together by a single wire it is an 1156,if it has 4 "horns" connected by 2 wires, it is an 1157.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
