Blowing fuse when heater cuts on...
Old Oct 12, 2003 | 02:42 AM
Pimpinfolyfe's Avatar
when ic ut my AC or heat on my fuse blows...dunno why thanks for your help..i also replaced the blower not to long ago
Old Oct 12, 2003 | 10:33 PM
onebinky's Avatar
Sounds like a short, trace your wires back from the blower and see if any of them have cut insulation and are touching. A less likely theory is that it's the blower motor itself. It could be worn and its drawing to much amperage, or it could have siezed up and welded the coils together inside. If the fuse is blowing instantly though, it's probably a short.
Matt
Old Nov 29, 2003 | 03:00 AM
TorchTA's Avatar
*arise from the grave*
hmm. so long as i dont hit the gas or anything mine works fine...but---the fuse ultimately blows. short or blower motor?
-JT
Old Nov 29, 2003 | 11:37 AM
onebinky's Avatar
If when you accelerate or something it blows right away, Id say its a shorted wire.
If you look at the fuse and it looks like the element exploded, most likely it's a short. If you look at it and it's just a slight break in it, it probably happened over a while and is possibly the blower motor's coil on its way out.
Good luck
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
64goatman
Sep 9, 2015 01:09 PM
90formulaVortec
Sep 3, 2015 09:26 AM
