question on wipers
Old Nov 2, 2003 | 12:34 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
question on wipers
My bros friend recently fixed my heater core. But however now the bug spray or wipers dont work...I see a purple and yellow wire hanging, and a screw hole next to another screw hole. One has a screw in it with a wire and the other one is empty.
Also in the engine area there is a wire hanging loose from the motor. Theres the big harness attaced but a little one is out of it and I cant find a place for it. Any help on what I can do to get my wipers to work again would be much appreciated. I can take pix if needed too.
Nate
Old Nov 2, 2003 | 10:32 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If you are talking about the plug I think you are, it goes into the absolute bottom of the wiper motor. However, I do not think that this wire controls anything other than the wiper motor itself, so I am going to ask if the washer pump ran before the motor assembly was unplugged. If it didn't work, than you can go out to your local parts store and order one. If I am incorrect at this point, you will need to add a pic so I can point myself and you in the right direction, or better yet, just add a pic anyways.
Old Nov 3, 2003 | 04:56 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
I got it working. My friends dad tapped some piece with a wrench or somethin. He said it may work for a while, but it it stops again I should get another motor. How long you think it would last? thx for the help. Problem solved.
Old Nov 3, 2003 | 08:59 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Those motors are cheap. I almost got one off eBay for $15 including shipping. But I'll tell you right now that GM used two different wiper motors. I have seen one from a Camaro the same year as my bird and the motor was completely different.
Old Nov 4, 2003 | 05:02 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Ya Ill prolly just stop by autozone and get a new one if problems happen again.
Old Nov 4, 2003 | 09:03 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Beware, wiper motors aren't cheap. By brother-in-law, several years ago, before he got rid of his second gen Camaro, had to dish out somewhere in the ballpark of $80 for a rebuilt unit for that same car. It sounds like that motor has one of two problems: either it has a loose electrical connection inside the housing, or it has a burnt-out starting winding that operates only when the motor gets a hard vibration. My dad's car has a cooling fan doing the same thing. Tap on it with a hammer, close the hood, or go over a nice bump in the road and all of a sudden it works, sort of.
Old Nov 5, 2003 | 06:37 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
damn 80.00 is kinda expensive for that little thing. Ill prolly end up getting one out of a junkyard like suggested to me. Itll end up being cheaper there.
Old Nov 5, 2003 | 07:25 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Found one for you on eBay. This is the link:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33657
The auction starts at $5 and you can get it cheap. DO NOT ever go to a junkyward for electrical parts, especially those under the hood. I've done so three times now and none have worked.
Old Nov 6, 2003 | 06:58 AM
icebird_1981's Avatar
i got a used one from a 83 z28 if u want it.
Old Nov 6, 2003 | 07:44 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
there are 2 designs that im aware of (there might be more)
one has the windshield washer pump built into the motor... my old 82 camaro had this....
the other has no windshield washer on it, its just a wiper.... its slightly thinner... my current 91 vert has this
Old Nov 6, 2003 | 06:24 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
well here the link to my site with my car pix. I think it has the motor included in one of the engine pix...
http://www.angelfire.com/ri2/dropdea..._Document.html
Also if anyone has one they want to sell you can IM me at Xincubusdemon69X on aim. Nathanbourbonniere@hotmail msn messanger or just PM me. Well make arrangments there. I can take more pix if needed.
Nate
Old Nov 7, 2003 | 07:17 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I looked at your pics, and I must first say "Nice sub system, man!" I have one of those myself. Do they sound good in that box?
Now, to get back to the post: Needs a clearer pic of the wiper motor so someone can tell you whether you have a separate washer pump or not, although to me it looks like mine in that it has the washer pump built in.
Old Nov 7, 2003 | 07:35 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
when I get some free time Ill get some pictures. Maybe tommorow if i get the chance.
Old Nov 8, 2003 | 01:57 PM
i got this one, its off a 83 Z28> i posted a pic so u could see if its the same as the one u have.
Frozer!!!
Jan 19, 2024 04:55 PM
siberian3rdgen
Interior Parts Wanted
Aug 31, 2015 09:37 PM
Randomtask2
Aug 26, 2015 03:34 PM
redmaroz
Aug 16, 2015 11:40 PM
slade5612
Aug 11, 2015 07:19 PM
