Radio Quirks
Old Nov 11, 2003 | 09:18 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Radio Quirks
Hey guys. So on my 84 Trans Am, sometimes the radio comes on when I start the car, sometimes it doesnt. Most of the time it doesnt actually. I have an aftermarket JVC CD player in there and yes, everything is wired up right. I have to hit various switches to turn the radio on and what switch it is differs from day to day. For instance, when I hit turned on the interior lights tonight, the radio came on. Earlier today, I had to hit the headlight switch. Other days its the defroster switch, the brakes, etc. What the hell is going on here??
Brian
Old Nov 17, 2003 | 02:47 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Re: Radio Quirks
Originally posted by Slepewesel
When I turned on the interior lights tonight, the radio came on. Earlier today, I had to hit the headlight switch. Other days its the defroster switch, the brakes, etc.
Are you positive the wiring is hooked up right? Did you install it, or did a friend? What is the model number on the unit.... and did you have the color codes sheet to work with?
Old Nov 18, 2003 | 08:20 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
From the sound of it you may have a grounding issue.
Did you ground the radio to the brown wire or the black wire in the harness?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
