Battery Draining, help please.
Old Nov 22, 2003 | 08:05 PM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
I took my car over to my girlfriends. When i got there i tried to start my car again, and the battery was dead. It still turns over just real slow, to slow to start the car. I had the alternator tested a few weeks ago and its fine, what else could it be? I think my battery is good. Im confused. Any suggestions would rock. Thanks
Old Nov 22, 2003 | 08:37 PM
twiztid dreams's Avatar
Car: 84 Firebird
Engine: 2.8l
possibly the starter
Old Nov 22, 2003 | 09:06 PM
Car: 84 Z28
Engine: 355c.i.
Is there a wayt o check this. I did do a search and found tons of stuff im gonna check, sorry i wasnt thinking
Old Nov 23, 2003 | 06:36 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
First thing is to take the battery and have a load test done, most chain auto stores do it for free. I doubt it is the starter, usually they won't turn at all when they fail. Charge the battery before you have it tested, otherwise you will be told it's bad and they will want to sell you a new one. If you have a voltmeter charge the battery and measure the voltage. It should be 12.6 volts when charged. Let it sit for a few hours then measure it again. If it drops below 12.4 volts replace it. Otherwise you may have a parasitic drain, you will need to wire a test light in series with one of the battery cables, if the light glows then you have a drain. Pull the fuses one by one until the light goes out and that will isolate the circuit causing the drain. Normal drain should be less than 15 milliamps in most third gens.
Old Nov 23, 2003 | 06:24 PM
Car: 84 Z28
Engine: 355c.i.
I got it fixed today thanks. Somehow on the back of the alternator, the post and the 2 wires were not making good contact. I feel dumb
Old Nov 24, 2003 | 01:59 AM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
My old battery wouldn't hold a charge long enuf to start the car more than after a day. I bought a new battery and now its fine. Perhaps ur battery cannot handle cranking over the engine.....
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
jaridjohn
Oct 5, 2015 07:01 AM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
