Car won't shut off - Ignition lock cylinder?
Old Nov 22, 2003 | 10:03 PM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
Hi all...I just performed some searches, and it looks like my problem is my non-VATS ignition lock cylinder dying, I can't shut the car off, the cylinder is locked in the "on" position. It'll crank fine, but it won't shut off...I had to disconnect the battery...
Couple of questions on replacing it....
First, I believe I need a lock plate depressor tool, can I get one at O'Reilly's or Autozone?
And second, I assume I can use a standad GM lock cylinder; I won't need a special dealer only model?
TIA....
Old Nov 22, 2003 | 10:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
yes, you will need a tool for pulling the steering wheel and a lock plate depressor tool available at almost all auto parts stores. Yes, you just need a standard GM lock cylinder since you do not have VATS.
The Trickster!!!!!!!!!!!!!!!!!!!
Old Nov 22, 2003 | 10:26 PM
HM Murdock's Avatar
Thanks, I fortunatly already have a puller, but wanted to be 100% about the cylinder. Thanks!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
ZsTransAm
Aug 11, 2015 07:30 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
