Installing help
Old Dec 13, 2003 | 10:46 AM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
Installing help
Next week I won't to install a fire extinguisher and the bracket on the passenger side of the car but I don't want to hit any wires or other important stuff. What is was thinking was to install it on the paasenger side walls near the side of the E brake or radio.
Input appreciated seeing as I don't want to mess something up.
Old Dec 14, 2003 | 04:42 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Some help would be nice
Old Dec 14, 2003 | 11:33 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
the center console is made out of plastic, that section of the console isnt too crowded with wires, only power windows, and wiring for the shifter(automatic only) and power mirrors, if u take the top part of your console off so u can see where u are drilling, it should be a cake walk
Old Dec 15, 2003 | 02:57 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
The plastic seems to weak plus I have a BM megashifter and I really can't just take the top of the center console off to easliy.
How about almost on the floor behind the radio.
Old Dec 15, 2003 | 03:08 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
i wouldnt know, someone else feel free to add any helpful info to this thread
Old Dec 15, 2003 | 07:12 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i mounted mine in between the two rear seat bottoms.....looks great there and out of the way, but easy access.
Old Dec 15, 2003 | 09:20 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Sounds good right on the hump.
Nothing to worry about under that??????
Old Dec 15, 2003 | 11:09 PM
xpndbl3's Avatar
Car: 1984 Z28
there's a driveshaft down about 6inches.....don't worry about that thing though. Nothing electrical to worry about ....just cut a little slit in the carpeting with a razor blade, pull back the carpeting with a screwdriver, drill your hole and put the carpeting back and screw her in. Good luck!
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
