Tech: How to properly wire your electronics (Part 2)
Old Jan 12, 2004 | 12:52 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Here's part two. This was too image-intensive, so some of the images have been converted to links that you need to click. Sorry.
Wire connections
There are a lot of different ways to connect wires, but only a few that will provide years of trouble-free reliability.
In most cases, the best electrical connection can be made by soldering the two wires together, and covering the joint with heat-shrink tubing. Make sure you slide the heat shrink tubing over the wire first, and slide it far enough away that the heat of the soldering won't melt it. When soldered properly, the solder will be drawn THROUGH the copper wire strands. You should apply the heat to the bottom of the wire, and touch the solder to the top. This will allow it to flow all the way through. If you're melting the solder with the tip of the iron, you're not doing it right. The heat of the wire should be what melts the solder.
Another type of connection that is considered adequate is the use of butt-connectors.
Strip approximately 1/4" of wire, stick it in one end, and crimp. Do the same with the other piece of wire. For interior wiring, this is adequate. If you're outside, you want to take additional steps. You want to use a little bit of di-electric grease on the bare wire before inserting into the butt connector, and you should also cover the entire connection with heat-shrink tubing. Make sure you slide the heat shrink over the wire BEFORE you crimp! If the wire is crimped properly, you should be able to tug on it without having the wire pull out.
An alternate to the bullet style connectors is the closed-end connector. You stick 2 pieces of wire in together and crimp one end.
http://www.partsexpress.com/images/095-560t.jpg
This style is a bit faster than butt connectors, but takes up more room, and can put strain on the wires if they are pulled tight.
Another alternate is the wire nut.
http://www.partsexpress.com/images/095-460t.jpg
These are adequate for TEMPORARY connections, but should not be used permanently. Vibration or tugging on the wire can cause them to come apart.
When you crimp these connectors, the cheap $5 crimpers that you buy in K-mart don't cut it. They only crimp a small part.
This quality pair of Klein crimpers sell for about $25 and are well worth the cost:
Whenever you need to tap off of a current wire without cutting that wire, you can use what's called a "wire tap". There are a couple different varieties. The most common style looks like this:
There are 2 spots for wires to go into. One passes all the way through, which is where the wire you're trying to tap into goes. This won't interrupt the flow of current through the wire. The second spot is where you put the end of the new piece of wire. You then use pliers to push the metal piece down, which connects the two electrically. These are available pretty much everywhere, but are clumsy and not very convienent. The preferred style looks like this:
This pic shows them in the closed position. These pieces clamp right onto an existing wire much like the previous style, except that you don't have to screw with having your 2nd piece of wire lined up. You just clamp this into place, then attach a male disconnect to the other wire. You can then plug them in together. Not only is this easier, but it's easy to unplug later on, and also gives you a good test probe point later on if necessary.
For any type of wiring that you may need to remove, it's always a good idea to use disconnect type terminals. There are many styles, including flat and bullet . Both the flat and bullet are available in fully insulated and partially insulated styles. I've only shown the partially insulated style, because they are easier to see. I prefer the fully insulated for obvious reasons, but there are times where the other style can be preferable.
For attaching wires to screw-style terminals on equipment like amplifiers, there are fork style connectors.
When selecting electrical connectors, the color makes a difference. Yellow is for 12-10AWG. Blue is for 16-14AWG and red is for 22-18AWG. Make sure you use the proper size. If you use one that's too big, it won't secure the wire properly.
Grounding
Properly grounding your electrical components is vital if you expect them to perform properly. Whether it's fog lights or a stereo amp, bad grounding can create all sorts of problems.
Rule #1: Location.
The location of your ground is very important for a few reasons, and the type of equipment that you're hooking up will dictate where you're best off putting your ground. For instance, if you're hooking up stereo equipment, you need a ground location that is going to minimize conducted radiation. Conducted radiation is sometimes called a "noisy ground". For example... if you hook your head unit or amplifier ground to the same spot that your directional light circuit is hooked to, every time your directional lights go on and off, you can hear a popping noise in your music. This is because the directional light circuit is an unfiltered circuit that produces stray voltages in the power and ground lines. These stray voltages are "noise". The closer you get to the grounding point of a circuit like that, the more noise your equipment will be susceptable to. So... where do you ground stuff? Well, if you're mounting the amp in the back of the car, stay away from the very back portion where the tail lights and hatch motor are grounded. A better spot would be a little bit farther forward, like above the rear wheel wells. If you're grounding something up front (like the factory head unit) and you find that the factory radio ground isn't sufficient, run the ground over to the passenger kick panel area, or even over to a passenger seat bolt. The driver side kick panel is noisy, as is most of the firewall. A lot of stuff grounds there.
If you're dealing with other equipment, such as lights, you don't have to worry about those things being effected by noise, but you DO have to worry about these things effecting other equipment, like your radio. Generally this isn't an issue because lights get grounded outside, very far away from any stereo grounds. Your primary concern for grounding this type of equipment is simply to find a good spot that will offer a clean electrical path to the chassis. Bumpers can seem like a good ground for your fog lights (well... not on a thirdgen, but stick with me here...), but they aren't. When you ground to a bumper, the electrical path to the chassis is usually through some bumper bolts. Over time they corrode and don't conduct well. Likewise, the point where the lights are grounded to the bumper is usually exposed to the elements and won't take long to corrode. A better choice is to run the ground into the engine bay, and find a clean, dry spot that won't be as susceptable to salt and corrosion.
Rule #2: Make sure the connection is as good as possible
The best location in the world isn't going to help much if you don't actually take the time to make sure the connection is as good as possible. If you don't have a good solid ground, the resistance goes up, and that causes all sorts of problems. With audio equipment, it can result in something called a ground loop, which is what results in alternator whine in your music. With lights and other equipment, if the resistance goes up too high, the equipment just won't work, or even worse, it'll ground through other equipment, which can result in a whole host of odd, unexpected problems that can take forever to track down if you don't check the ground first. For example... in my old firebird I had my air horns and one of my fog lights grounded to the same point. Everything worked fine for a while, but once that ground began to corrode a tad, only one fog light would work with the switch. If I pushed the button for my air horns, the horns wouldn't work, but one of the fog lights would come on. Moving the grounds and making sure they were done properly eliminated the problem permanently.
So anyway... how do you secure a good ground? If it's inside the car, find a good thick piece of metal to drill into. Make sure you're not drilling into something important (like your gas tank). DO NOT drill anywhere into the hump behind the rear seat. Even if you don't drill all the way into the gas tank, having screws in that metal can puncture the gas tank in an accident and cause an explosion. Find a different spot. Anyway... the screw you use should be large enough to tightly hold down the washer and ring terminal. Your ground wire should always be terminated with a ring terminal:
The color of the plastic indicates the gauge wire that the terminal is designed for. Yellow is for 12-10AWG. Blue is for 16-14AWG and red is for 22-18AWG. Make sure you use the proper size. If you use one that's too big, it won't secure the wire properly. Crimp them securely with good crimpers.
After you drill your hole, you want to take a razor or screwdriver and scrape away the paint until you have bare metal in the spot where the ring terminal will touch the body. You want a clean, metal to metal contact point.
When you attach the ring terminal to the body of the vehicle, use a "star" washer (also known as a tooth washer) between the ring terminal and the body of the car:
The star washer will help dig into the metal and provide a better connection.
When you're grounding equipment outside the vehicle (such as fog lights) you want to follow the same procedures, plus add a few additional. Generally you can find an existing body bolt to ground to instead of drilling a new hole. Any crimped connections you make should included a dab of di-electric grease in the connector before you push the wire in. Heat shrink tubing should be used to make an air-tight seal between the connector and the wire itself. In cases where that's not possible, wrap it tightly with electrical tape. In many cases, soldering is an even better option than crimp connectors, although wires that are prone to high amounts of vibration are better off with the crimp connections and heat shrink tubing. You want to clean off the grounding spot just like mentioned above, but you want to make sure that you use di-electric grease on the ring terminal and star washer. If you don't, the connections will quickly rust and ruin the good ground. When choosing a pre-existing bolt to use as a ground, make sure it's one that's part of a good chassis point (radiator support bolts for example) or at least something that's an integral part of the unibody structure (like a fender bolt). You don't want to use bolts that are part of a metal bumper, because they are only attached to the rest of the body through a few bolts, and if those corrode, your whole bumper is no longer a good ground. Chosing a location that's free from salt & water spray will also keep your grounds good for a much longer period of time (which is another reason why the bumper is a bad choice).
Rule #3: Proper gauge wire
Make sure that the wire you're using is of sufficient size. If you use wire that's too small, the resistance goes up, and you also have a potential fire hazzard on your hands. For example, if you have a powerful stereo amp, and you use some tiny wire for the ground, the resistance will be high enough to induce a ground loop, just like if you had a bad ground. You can check your ground all day long, and it'll measure fine, but when you pass big current through it, it'll no longer be sufficient. Likewise, if the wire is really too small, it can get hot and melt. This can obviously be very bad.
Old Mar 21, 2004 | 04:52 PM
mbtech's Avatar
Car: 83 comaro
Engine: 350 tpi
Transmission: 350
To be honest the conectors shown will only cause problems down the road. due to moisture and air it will corrode and cause lots of problems. The only true way to connect things is to solder and then heat shrink the connection any other way will cause Gremlins.
Old Jun 25, 2004 | 07:11 AM
Jim85IROC's Avatar
Using those connections shown is a perfectly reliable method if you take the time to do it properly and use di-electric grease. Solder seems like the miracle cure, but it's got its own drawbacks. In an automotive environment full of vibration and shock, solder joints can crack and become very unreliable. It's a toss-up as to which will give more reliability in the long term.
Old Jun 25, 2004 | 10:29 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i'll just point out real quick that every stock connector on your car is crimped. stuff like that doesnt instantly rust.
Old Jun 25, 2004 | 07:49 PM
mbtech's Avatar
Car: 83 comaro
Engine: 350 tpi
Transmission: 350
In a stock situation all or almost all conectors are soldered or heat shrinked the only exception is some ground points. besides only crimping and not soldering in aditiont will only come loose in time causing later problems and hair loss due to you pulling it out by the roots trying to find the problem. Most important to do this if it is under the hood. key word thought is heat shrink every thing atleast.
Old Nov 3, 2004 | 07:09 PM
HamiltonAudio's Avatar
Car: 1982 Camaro Z28
Engine: hot 355 ci small block
Transmission: built TH350
just looking thru the stickies here. I see you guys list the use of butt connectors and scotch loks as acceptable methods. I can tell you from experience that the use of these two items in most car audio shops will result in an immediate curb stomping.
When connecting one wire to another in a vehicle, there is simply (imho) no replacement for strip/solder/tape. period. You mention shock and vibration - when wires are soldered correctly, the solder joint itself is stronger than the wire its bonding. And every harness and wire i've ever tapped into over the years is far from being rigid enough to have the shock/vibration of driving affect it negatively.
scotch loks pierce and partially cut through the wire when they're used. all the current passes across a little tang of metal that has simply cut the insulation (and in most cases strands of wire too). lots of people like to use them to tap into wires that are hard to get to (the easy way out). In 10 years as an installer, I have YET to find a wire I couldn't get my strippers on, and a soldering iron to. And a butt connector is just plain lazy. In the time it takes you to strip both wires, line them up and crimp them, I've already soldered mine. Now do the pull-test - my connection causes the wire to break upstream of the connection (again, its stronger than the wire). the butt connector simply lets go.
all in all, great FAQ's and information. I just disagree with the use of mechanical fasteners like the scotch lok and butt connector.
bmoney
Old Nov 4, 2004 | 07:23 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
You'll be fine with a properly crimped connection. I like the ones with the double crimp, so you crimp to the wire and above that crimp to the wire and insulation. Gives it more pull strength, but not at all necessary (just me being obsessive). I'll also add that you should get good crimp connectors and a good crimper (like the one Jim showed). With the cheaper crimps over time the plastic can get brittle and come loose or fall off. The cheap crimpers will pierce the plastic insulation some times. Light bulb grease on the wire first helps to.
I've seen the problem Jim mention with soldering a LOT, usual from bad soldering jobs (to much solder) connecting a larger wire to a smaller one. The smaller one will break right at the edge of the solder. There are ways to help prevent this though.
Using a stiffer heat shrink tubing over the connection will act as a strain relief. Extend the tubing about 1 inch past the connection. Also use a small zip tie to hold the two wires together, more strain relief. This is the method I use the most.
HINT: For connection that will be exposed to the elements/high humidity, add some silicone under the heat shrink tubing BEFORE you shrink it down. Over time (a lot of time) moisture can wick up the wire under the insulation (not common but can happen). This can give you an open under the insulation. Adding the silicone will keep the moisture out (again me being obsessive).
I just re-did A harness on my truck (not TGO friendly) for auxiliary lights. 2 100W floods and 2 100W spots. About 30A. Every relay socket and connector gets light bulb grease, ever connection is made like I said above (solder/silicone/heat shrink/wire ties). It's all Zip Tied up and covered with split loom. I expect no problems from it.
I don't like the scotch locks ether, and for the same response HA stated above. But I try to avoid tape when ever possible. And you should only buy GOOD QUALITY tape. The cheap stuff likes to lose it's sticky over time and can unravel. A wire tie on the end or the tape is bulky but will keep this from happening.
If I'm using tape it's because I'm tapping into a wire so I can't get tubing over the connection with out cutting the wire I'm tapping. In this case I like to start the tape at end of the connection with only one wire, then tape over the connection good and run the tape over the two wires together by about an inch. That's the end of the tape job, the tape will unravel from here, not the start of the tape. Now use a small wire tie here (over the two wires and tape) and it will work as a strain relief and work to hold the tape tight.
Did I explain that OK? Questions, comments?
Old Apr 29, 2005 | 01:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I just thought i'd share my personal experiences:
heat shrink typically shrinks 2:1, is pretty self explanatory..
dual wall heat shrink: usually double the price or more, goes 3:1 or even 4:1 shrink ratio, and the "dual" part of the dual wall means the outside is a standard heat shrink sorta deal, and the inside of the tube is like hot glue... Prevents moisture from going in. Very worthwhile.
I like to:
-grind/cut off the plastic insulation on a connector, unless you can find them uninsulated...
-slide the heatshrink on
- crimp on the connector (I think this is the electrical connection, electricy flows better through the metal connector then the solder right? (as opposed to MR dude's, opposite...)
- then solder
-then heatshrink
You shouldn't have any stress on the wire, it's not a toy, don't yank on it! It should be under your carpet or whatever and out of sight out of mind.
Old Apr 29, 2005 | 08:07 AM
I like to:
- then solder
-then heatshrink
If you're doing little jobs here and there, being ultra **** about grinding the insulation off and adding heatshrink might be ok. But you won't really see this in a pro shop as its not really necessary and wastes major time.
In places where extra insulation is desired, I've always used regular insulated terminals and then a piece of shrink that goes over the ENTIRE connector. Shrink it and the connector now has a condom In 10+ years I've yet to have any issues with connections done this way.
I think the bottom line is this - when connecting two wires, a solid connection is easy to achieve. With proper heat, soldering is very quick and easy to do, and is by far the strongest and fastest method of securing the wires. And contradictary to what people think, the solder induces so little resistance that its a non-issue. In fact, if it was that bad, would it be recommended that we solder to sensitive databus wires in vehicles when bypassing security/immobilizer/etc in remote starts? Nope, but we do it every day with NO issues.
All the suggestions here are solid ones for the DIYer who doesn't want to get into problems down the road. For a professional installer, they're overkill...thats all.
bmoney
Old Oct 5, 2006 | 07:58 PM
djsub1's Avatar
HELP ME!!!!!!!!!!
OK SO I WENT OUT OF TOWN FOR A 5 MONTHS AND MY FRIENDS DECIDED TO DO THE TUNE UP IN MY CAR...SO WHEN I RETURNED....THE CAR WAS DOING EXPLOSIONS AND..GOES OFF AFTER A 15MIN OF BEING ON......I THINK WHEN THEY CHANGED THE SPARK PLUGS THEY DIDNT DO ONE AT A TIME ...SO I NEED TO FIND OUT WHAT THE PROPER WAY TO DO SO....CAN AYONE HELP WITH THIS....(HOW TO REDO SPARK PLUGS THE PROPERLY)
Old Oct 20, 2007 | 10:41 PM
jon murphy's Avatar
Re: Tech: How to properly wire your electronics (Part 2)
Absolutly true. Any pliers works IF you solder it afterwards.
Old Sep 17, 2008 | 10:33 PM
gmpptech's Avatar
The connectors shown are not exceptable. The OEM's don't use any of these. OEM's use crimped terminals in connectors with position assurance clips and sealed with weather pack seals for the terminal, and between connnections. And they don't do all of that because the dime store connectors shown are any good.
I'll also add that OEM's use a specific crimping pliers that apply the correct crimp and torque for each type of terminal depending on style, shape, and size. And another to crimp on the weather pack seal
Old Jun 16, 2010 | 05:15 AM
RyanEricW's Avatar
Crimping is terrible in regards to reliability vs soldiering. The only crimping I ever find I do is for B+/B- cables, or if I need to wire an external accessory, which in that case, I buy the expensive crimping ring terminals that are weather proof. They crimp over the wire, and you take a lighter to it like heat shrink, and it conforms to the wire; it seals the air/moisture out.
I see people crimping connections to amps all the time and although it looks nice, it is a pain especially when people put too large of connectors and shove it in a small connector hole. You go to pull the connectors out and half the time, they detach. Useless. >:O
Old Aug 25, 2010 | 08:42 AM
Jim85IROC's Avatar
Crimping is like anything else... if you screw it up, it's going to be screwed up. If you do it right, it's reliable.
Old Aug 14, 2011 | 02:59 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Wire connections
Grounding
Rule #1: Location.
Where's the pictures? This info is almost worthless without the pictures! Unsticky this thread. No point in having it up if the picture reference is gone.
Old Sep 11, 2013 | 08:08 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I found some crimp connectors that also solder and shrink to the wires. They are available from McMaster-Carr and I have used them to reroute my power wires from across the top of the motor to down the back side of the motor like on the 1st and 2nd gen cars. Here's a link to them. Go down to the section called splices and they are called Sure-Connect sealed butt splices.
http://www.mcmaster.com/#crimp-on-wi...ectors/=ogl5yz
Just wanted to share other options
Old Sep 11, 2013 | 09:56 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Here's a new product out that involves no heat, but offers a weather tight seal......
http://www.delcity.net/store/Cool!Se...ector/p_802081
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
1nastygta
Aug 8, 2015 07:38 PM
