Turn signal problem
Old Apr 18, 2004 | 07:42 PM
camaro87's Avatar
Car: 1987 IROC-Z/28
Engine: 305 cid V8
Turn signal problem
Hello,
I am having a problem with my turn signals. What happens is when I attempt to signal a turn (right or left), the dash light and outside lights stay on, they don't blink. Hazards work fine, and all bulbs are working.
I've checked a bunch of other posts and have basically determined at this point the turn signal switch assembly in the steering column is bad. I don't have the time nor tools to fix this myself right now, so I'm just going to bring it to the shop.
However, in the process of narrowing down the problem, I've noticed that apparently my '87 IROC-Z/28 does not have the turn signal flasher relay installed (it's not even there, just missing)! This surprised me, as the turn signals were flashing fine before, then all of a sudden they just quit flashing.
Also, my wiper delay isn't working. I'm thinking the problem is the wiper delay switch which is also in the steering column, as both the high and low wiper settings work fine.
So I figure I'll just go to the shop and kill two birds with one stone as both these problems seem to be in the steering column.
Any ideas on the lack of a turn signal flasher relay, though? Is this normal for my model?
Thanks,
Tristan
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
